Shower/Tub Faucet Pressure Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-21-2015, 09:05 AM   #1
Hey everybody!
I bought a duplex recently and am having issue with the tub/shower pressure. This unit (bottom of a two story duplex) has 3 beds and 1 full bath. I have posted a video helping illustrate the situation and to provide a visual.
VIDEO - https://youtu.be/hi522pm5vqw
In a nutshell - the shower pressure is so low that taking a shower would actually be impossible. The tub faucet seems to be delivering more water, but not by much. My observations:
- the bathroom sink pressure seems ok
- the kitchen sink pressure seems ok
- water from the outside hose bib delivers plenty of water
What could be causing this? It has been like this since I bought the home. I believe its a more recent thing as the tenants (moved out just before I purchased the home) would have certainly not put up with it. Also, this would have shown up in the inspection. There are no tenants living there now but the top tenants have never complained about water pressure.
If anyone has any tips/pointers, I would greatly appreciate your feedback!
Brickshaw is offline   Reply With Quote
Old 05-21-2015, 09:06 AM   #2
Video
Old 05-21-2015, 09:30 AM   #3
Rewards Points: 1,930
Whats the house water pressure at the meter?
Ghostmaker is online now   Reply With Quote
Old 05-21-2015, 09:33 AM   #4
Honestly I don't know, I would need to check.
Old 05-21-2015, 09:42 AM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
looks like there is a bit of calcium buildup on that shower head which would weaken the the flow as well as clog the volume restrictor built into the head. Take the shower head off the neck and see how the water flow looks. Also, the pressure at other areas did not seem particularly strong. You might want to make sure that the vavle is open all the way at the meter, or to the apartment itself.
Man of many hats
wrangler is offline   Reply With Quote
Old 05-21-2015, 10:08 AM   #6
Special User
Rewards Points: 1,230
My uneducated guess is pressure is prolly okay based on that outdoor hose bib's flow rate.
Since the problem is limited to the tub/shower, my mind goes to the valve. Modern single-handle valves are typically pressure-balanced. This is in an attempt to prevent you from getting scalded when you're showering and someone uses cold water somewhere else. However, this also means that if pressure is low on one side (hot or cold), the pressure will be restricted on the other side (cold or hot) to match (balance).
Since the outdoor hose bib flows well, the problem is likely the hot water.
If the previous occupants never flushed the hot water heater, there may be a lot of sediment built up. Some of it may have gotten sucked up the dip tube and is now lodged in your tub/shower valve. I'd start out with flushing the water heater. If water is slow to come out the flush valve, then the water heater's cold supply shutoff valve may be gunked up. Turn it off and on a few times (if it's frozen, there's yer problem).
Once you're sure the problem is not the cold supply valve, check for any energy-saving devices on the heater inlet and outlet. These tend to jam up with sediment and block flow. If you're sure they are not the culprit and flow is still low, pull apart that tub/shower valve cartridge and look for sediment or wear.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-21-2015, 10:11 AM   #7
tylernt - Would changing the cartridge be a viable solution before getting into all of that?
Old 05-21-2015, 10:15 AM   #8
Special User
Sure, but the cartridge can be a little on the spendy side depending on the model, and that wouldn't address the possible underlying sediment problem that caused the malfunction in the first place.
If you're looking for the easiest route, I'd replace the cartridge but still flush the water heater. Heaters should be flushed annually anyway.
New Kitchen Faucet with Pressure Bump John1219 Plumbing 3 02-10-2015 05:15 PM
Water pressure problems maddog1 Plumbing 7 11-10-2014 05:37 PM
well pressure tank or pump problems gatorchin Plumbing 7 04-04-2012 06:19 AM
New Moen faucet hot water low pressure derwood5555 Plumbing 6 02-25-2012 03:05 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
