Shower Stall Drain Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2015, 05:38 PM   #1
Rewards Points: 2
Hello Everyone. I have an upstairs one pc fiberglass shower stall that is leaking around the drain fitting. Take a look at the two photos attached. First one is the top piece that screws into the plumbing under the shower (flange broken).
Second one is the shower stall floor and the drain itself.
Here is my problem: I have been to Lowe's, home depot, special local plumbers supply, ace hardware, and two other local hardware stores looking for this fitting and have not been successful.
My fitting is either slightly smaller in diameter, or has different thread pitch or profile than ones available on the shelf.
I don't want to have to tear up drywall on the floor below to locate, tear apart and install an entire fitting. I'd like to just be able to find a fitting that matches this one and possible use just the top component of the fitting to replace my broken piece.
Since I have not been able to locate these parts, I am wondering if the shower was installed with discontinued hardware or maybe something that really isn't even a shower drain to begin with. Can anyone help??
Regards,
Jay
Shower Stall Drain Problems-today-372.jpg   Shower Stall Drain Problems-today-379.jpg
Jay1128 is offline   Reply With Quote
Old 06-20-2015, 05:47 PM   #2
Rewards Points: 582
that looks like a 2" oatey shower drain to me...
Shower stall leaking through ceiling below in kitchen mikestorm5 Plumbing 36 02-27-2014 05:49 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Can I add a shower stall drain to my sink drain yardeningplus1 Plumbing 8 10-30-2008 07:04 AM
