Shower Shutoff Valve Installation - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By ron45
Old 10-18-2017, 11:18 AM   #1
Rewards Points: 368
shower shutoff valve installation
Hi all. I wanted to add shutoff valves to the hot and cold supply lines to the shower, using the existing access panel shown below, where the arrows indicate where the valves would be soldered. A plumber told me that I needed an "inspection panel" instead so that the valves are visible and accessible all the time, in case of a leak, per the California code. The existing access panel is in a closet and would be covered by clothes so a leak in the new installation would not be visible.
Does this mean I need a separate access panel, at eye level and without a cover?
Thanks in advance for any replies.
paul_k is offline   Reply With Quote
Old 10-18-2017, 08:31 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 248
Re: shower shutoff valve installation
You should be okay in the closet. But then I don't live in CA. ....
This is really no different than shut off valves hidden deep within a kitchen cabinets.
Old 10-18-2017, 09:48 PM   #3
Rewards Points: 6,100
The Eplumber said, "" You should be okay in the closet""
I had to laugh...
jlhaslip and TheEplumber like this.
ron45 is offline   Reply With Quote
Old 10-18-2017, 10:06 PM   #4
Plumber
Rewards Points: 248
I had to laugh...
Yep that's called accessible........
Old 10-19-2017, 06:07 PM   #5
Rewards Points: 368
It may be difficult for me to solder standard shutoff valves after cutting the pipes. Anyone have good/bad experiences with "SharkBite" valves?
Old 10-19-2017, 06:59 PM   #6
Plumber
Rewards Points: 248
members here tend to except sharkbites
Moen Shower valve repair advice...????? MTN REMODEL LLC Plumbing 26 04-26-2017 07:04 PM
Shower Valve Assembly/Locking Nut rookie49 Plumbing 11 01-10-2013 11:14 AM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
