Shower Pulsing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2016, 06:40 AM   #1
Rewards Points: 145
Shower Pulsing
I have all new plumbing and the first shower of the day makes this pulsing noise for the first couple minutes. I took the low flow filter out and know I do have high water pressure 90psi. Is it air in the lines or coming from the hot water heater? Haven't tested with cold only. Any ideas?
kjmass1 is offline   Reply With Quote
Old 04-30-2016, 09:10 AM   #2
Rewards Points: 3,220
Re: Shower Pulsing
Normal water pressure is around 50-60 psi., yours is kind of on the high side. You may need a water pressure reducer valve installed and add an expansion tank to your water heater as well, set it to your incoming water pressure. May not be the problem, just better for your plumbing system. Just a suggestion.
Strange they didn't address that with all new plumbing installed. Call them back, and let them know your concern.
Please wait for the plumbers to respond. Thanks.
jmon is online now   Reply With Quote
Old 04-30-2016, 09:33 AM   #3
Rewards Points: 145
Re: Shower Pulsing
I've looked into adding a reducing valve. What does the expansion tank do?
The Following User Says Thank You to kjmass1 For This Useful Post:
jmon (04-30-2016)
Old 04-30-2016, 10:38 AM   #4
Re: Shower Pulsing
Once you add a reducing valve you create a closed loop system. The expansion tank gives the excess thermal water pressure a place to go when heated up.
Old 04-30-2016, 11:59 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 172
Re: Shower Pulsing
Does this only happen for the first shower? What is the brand of the valve and are you still under the builder warranty?
Old 07-22-2016, 06:41 AM   #6
Rewards Points: 145
Re: Shower Pulsing
We only take 2 showers a day so yes typically the first one.
I believe it was a danze brand. Not a cheap one.
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 02:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
