Shower Pan: Is There Anything Wrong Or Missing ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2016, 08:44 PM   #16
Rewards Points: 22
Best way
Do you have any tips? I As long as I use Redgard , fiberglass tape, and Several coats of Redgard over the seems, I do not need any other cement on the Durock, correct. I intend on putting at least 2 or three coats on the walls and at least three on the floor and seems, over the fiberglass tape.
rbannan1 is offline   Reply With Quote
Old 01-23-2016, 08:53 PM   #17
Retired Moderator
Rewards Points: 7,174
Originally Posted by rbannan1 View Post
Do you have any tips? .
Have you looked at the Latacrete site yet?
Old 01-24-2016, 03:38 AM   #18
Rewards Points: 22
Yes I have. Good info there. Especially the drain.
The Following User Says Thank You to rbannan1 For This Useful Post:
oh'mike (01-24-2016)
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-23-2012 11:14 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
