Shower Mixing Valve Isse - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 11-16-2016, 07:38 AM   #1
Rewards Points: 6
Hi. I've got a Kohler single-handle shower valve that started acting up a few days ago.
You pull it out to turn it on and rotate left/right to change temp.
When you turn it on it gets hot but as you turn it back towards cold it stays hot then suddenly gets very cold. (You can also hear the pipes make a slight "chunk" noise when that happens.
I don't know what valve model it is - haven't opened it up yet - but does it sound like the cartridge needs replacing? Thanks!
GregST is offline   Reply With Quote
Old 11-16-2016, 08:34 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,484
Re: Shower Mixing Valve Isse
Yes.
Cartridge sounds faulty.
Sully6541 likes this.
Old 11-16-2016, 08:36 AM   #3
Rewards Points: 6
Re: Shower Mixing Valve Issue
Thanks for the short and sweet reply.
Old 11-16-2016, 08:44 AM   #4
No problemo. This is most likely and easy one.
Don't buy and off brand cartridge to replace it. Get a Kohler one.
Have some plumbers putty, scotch bright pad, utility knife, and some Vaseline (some usually comes in the cartridge). Pretty easy process.
Old 11-16-2016, 09:09 AM   #5
Rewards Points: 6
Thanks again.
Old 11-16-2016, 05:20 PM   #6
Rewards Points: 1,866
Pressure balancing spool that is in the cartridge.
Old 11-18-2016, 03:29 AM   #7
Rewards Points: 38
Ghostmaker always knows the answer...the new pressure balancing spool is the only supply you will need.
SHR Plumber is offline   Reply With Quote
Tags
cartridge , kohler , shower valve
Shower Valve & Head Depth 325_man Plumbing 6 07-11-2014 08:41 PM
Moving/Installing new mixing valve... issues with framing rodney23 Plumbing 6 12-12-2010 03:32 PM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Is this a mixing valve problem? imola ghost Plumbing 2 05-31-2010 10:52 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
