Shower Leaking Downstairs Intermittently - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By DR P
  • 1 Post By akuhn235
Old 12-17-2017, 07:45 PM   #1
Rewards Points: 392
Shower leaking downstairs intermittently
What are all the possible causes?
The caulking looks fine.
Could it be the Moen cartridge?
enochian is offline   Reply With Quote
Old 12-17-2017, 07:58 PM   #2
Guapo
Rewards Points: 11,950
Re: Shower leaking downstairs intermittently
Why does the drain look off center? Is there a hand held shower head? Look at the plate behind the mixer valve. Is it caulked?
Guap0_ is offline   Reply With Quote
Old 12-17-2017, 08:06 PM   #3
Rewards Points: 392
Not handheld, but why does that matter?
I'm not at the property, but I'm guessing that plate behind the valve should be caulked?
Old 12-17-2017, 08:43 PM   #4
hkstroud's Avatar
Rewards Points: 6,694
Most likely leaking where the shower arm screws into the drop ell.
Pull the escutcheon around the show arm away from the wall and using a flashlight look in the hole for signs of water.
No.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-17-2017, 09:54 PM   #5
retired framer
Rewards Points: 15,496
If the valve is on an interior wall cut a hole on the back side and have a look.
Old 12-18-2017, 05:43 AM   #6
hkstroud's Avatar
No, the escutcheon around the valve can be remove to look inside.
Harold,
Old 12-18-2017, 06:17 AM   #7
Guapo
Handheld matters because I've seen the water run down the hose & drip behind the plate behind the mixer valve. That's why I mentioned both.
Old 12-18-2017, 07:24 AM   #8
Peace be with you
DR P's Avatar
Rewards Points: 1,860
calking never lasts so
never assume the calking is fine
in fact usually opposite is truer
cut out & remove all
clean with proper chems to ensure area clean & new calk bonds
pay special attention to corners and around door where water can pool or be trapped
an improperly installed calk job can make things worse even if it looks fine
this is regular maintenance and best place to start your elimination process
Peace
Nealtw likes this.
DR P is offline   Reply With Quote
Old 12-20-2017, 06:06 PM   #9
Rewards Points: 126
is it leaking when the shower is in use or at all times?
Nealtw likes this.
akuhn235 is offline   Reply With Quote
Shower leaking from ball joint phillipviana Plumbing 2 10-13-2017 11:00 AM
Shower is leaking, please help!! stefanross Plumbing 1 08-31-2015 05:00 AM
Knob for shower leaking abefroman Plumbing 13 09-16-2014 02:04 PM
Shower stall leaking through ceiling below in kitchen mikestorm5 Plumbing 36 02-27-2014 05:49 PM
Shower leaking into closet brianplaysmusic Plumbing 4 01-20-2012 09:12 AM
