Shower Knobs Have Metal Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-29-2015, 09:34 PM   #1
Rewards Points: 8
Shower knobs have metal pipe
Shower knob broken in the bathroom. So no problem right just buy new hardware and knobs and swap it out.
But mine has a metal pipe around it so I cannot change. Sorry don't know how to explain it.
Dillusion808 is offline   Reply With Quote
Old 08-29-2015, 09:51 PM   #2
Retired Moderator
Rewards Points: 7,174
Do you know what brand of faucet that is?
The silver tube usually unscrews---you may need to use a rubber strap wrench---
Old 08-29-2015, 09:57 PM   #3
Rewards Points: 8
No idea what model was in the house when I bought it.
I was thinking the valve was holding it in but I can't reach the valve nut. The metal tubing around it keep me from fitting something that can reach the nut.
I'll try get a rubber strap wrench but it didn't budge so far.
Old 08-30-2015, 05:14 AM   #4
Retired Moderator
Good luck--that tube is just decorative---a squirt of penetrating oil might help
SHR Plumber (09-02-2015)
Old 09-02-2015, 11:07 AM   #5
Rewards Points: 8
Thanks guys the strap wrench did the trick. Now next question.
Changed the valve, changed the seat, but the valve stem stick so far out. Did I buy the wrong kit? I'm guessing I did.
Shower knobs have metal pipe-1.jpg   Shower knobs have metal pipe-fullsizerender.jpg
Old 09-02-2015, 03:24 PM   #6
Rewards Points: 3,494
Maybe. Did you take the old ones with you to match them up.
jmon is online now   Reply With Quote
Old 09-02-2015, 04:55 PM   #7
Rewards Points: 8
Yeah thats what I thought. Home Depot must love me.
Couldn't get the old one off earlier so I bought the whole kit not realize the stems were different lengths.
Old 09-02-2015, 08:44 PM   #8
Rewards Points: 1,058
Just let it go and see what your wife says.
Toller is offline   Reply With Quote
Question about shower pipe longislander2 Plumbing 4 11-05-2013 10:38 AM
Steam from shower collects on pipe Eileen New York Plumbing 6 04-05-2013 01:35 PM
VA code says 1.5" inch pipe on shower drain wcarroll Plumbing 3 08-10-2011 11:07 PM
Flexible metal duct to absorb rigid pipe expansion RPWin HVAC 0 04-02-2011 12:59 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
