Shower Knob Brand - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2015, 10:22 AM   #1
Rewards Points: 119
Shower Knob Brand
I just finished putting in tiles walls in my shower and when I put the shower knobs back on, I discovered the splines of one of the knobs were stripped. Not sure why the knob worked before I took it off, but it just spins now. It sort of functions if I really tighten the screw, but of course that doesn't really last.
So, can anyone identify the brand of knob in the attached photos? Judging by the décor before I modeled I am guessing it could be as much as 20 years old.
It also has a sleeve/cover combo piece that screws in onto the valve stem first.
wvphysics is offline   Reply With Quote
Old 11-02-2015, 10:41 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 896
Why did you tile without replacing an old valve.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 11-02-2015, 10:57 AM   #3
Rewards Points: 119
Before I tiled the shower the knobs were working. I was not aware of any reason to replace the shower valve. The knob only had a problem when I put it back on after the work was done. The only thing I can figure was corrosion was helping the knob turn the stem until I removed the knob.
The Following User Says Thank You to wvphysics For This Useful Post:
jmon (11-02-2015)
Old 11-02-2015, 02:30 PM   #4
Rewards Points: 3,476
Take them with you to a plumbing supply or hardware store and try to match them up. You might get lucky.
jmon is offline   Reply With Quote
Old 11-02-2015, 03:44 PM   #5
Rewards Points: 5,348
This has nothing to do with the knob, working or not working. It has to do with updating the fixture that conforms to current plumbing codes. Pressure balanced units are now required to replace the older two handle units. They prevent hot water flashes if someone uses the cold water.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
ben's plumbing (11-02-2015)
Old 11-02-2015, 09:09 PM   #6
Rewards Points: 127
Also called preemptive. Plumbing fixtures don't last forever as you have found out. If the wall is open then that is time to replace fixtures. It's much easier and cheaper than having to repair it later.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
SHR Plumber (11-02-2015)
Need help identifying off brand shower cartridge jmac875 Plumbing 3 03-03-2015 05:54 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
I cannot seem to figure out how to take this shower knob apart... chatwithaninja Plumbing 4 09-10-2012 11:02 PM
Valley single knob shower faucet navig97 Plumbing 1 06-22-2010 06:25 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
