Shower Knob - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2015, 06:45 PM   #1
Rewards Points: 137
shower knob
In our bath/shower the middle knob that adjusts the water from tub to shower head can be turned back and forth with a pliers (with the knob off), but when I put the knob on it wont work. Are there different types of knobs?
debd is offline   Reply With Quote
Old 11-11-2015, 06:53 PM   #2
Rewards Points: 3,220
Yes, there are different types and sizes of knobs.
Make sure screw is tight and fits right.
If that's good to go, then the teeth on the knob itself are probably worn out and no longer able to sufficiently grip the stem to turn it. Get a new one. Take it with you to a big box, plumbing supply or hardware store to match it up. Just a suggestion.
jmon is offline   Reply With Quote
Old 11-13-2015, 02:54 PM   #3
Rewards Points: 137
Thanks for the help
The Following User Says Thank You to debd For This Useful Post:
jmon (11-13-2015)
Old 11-13-2015, 05:32 PM   #4
You're welcome. Hope you're able to get it working right again.
Need replacement for shower knob jkk Plumbing 5 06-14-2013 10:20 PM
help identifying shower knob jayleekay Plumbing 7 06-16-2012 03:12 PM
Newb needs help with shower knob repair mackdiesel Plumbing 7 05-22-2012 03:28 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
