Shower Installation - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By rjniles
Old 06-13-2016, 07:37 AM   #1
shower installation
I am installing a one piece shower in a new addition. What size hole do I drill for a one piece mixing valve in the shower. They do not state in the directions what hole I should drill
sticks41 is offline   Reply With Quote
Old 06-13-2016, 09:46 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: shower installation
Drill the size of the plaster ring on the valve.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
sticks41 (06-13-2016)
Old 06-13-2016, 10:16 AM   #3
you stated drill the hole the size of the plaster ring? Doesn't the ring stay on the back side of the shower? If I drill the hole that size, the whole ring would go right thru the shower?
Old 06-13-2016, 12:04 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
The plaster ring should be flush with the finish surface.
sticks41 likes this.
sticks41 (06-14-2016)
Old 06-13-2016, 09:29 PM   #5
Rewards Points: 1,856
Older plumbers normally secure the valve with two by fours in the wall.
Makes life easier when removing bad cartridges in the future.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 05:15 PM
