Shower Handle Doesn't Turn + No Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2015, 01:21 AM   #1
Rewards Points: 6
Hey guys. Long time fan of this forum and excited I finally get a chance to post something on it for once. I recently bought a new shower head system w/ knob and all for my bathroom since it needed a new one pretty badly. (The old one was turning greenish yellow? Not very appetizing.) At any rate, I had it installed but two things I noticed were:
(1) The shower knob is a single handle that turns counter-clockwise. When I goto turn the knob, it turns very short and doesn't feel like its turning all the way. It turns for an inch or two and stops. It just seems like too short of a range for a shower knob?
(2) The water is very lukewarm. I think the new shower system may have a limiter built in. Can this limiter be removed? If you turn the handle to the hottest water temperature setting the shower water just comes out luke warm or just slightly warm.
I googled some articles for it without much luck. =(
If I left out any info that would help please let me know and I'll do my best to answer. Really appreciate any advice from ppl who might've experienced this kind of shower/bathroom problem. Thanks in advance for any help.
wcc201 is offline   Reply With Quote
Old 12-25-2015, 06:56 AM   #2
Rewards Points: 352
What kind of shower valve is it?
plumberinlaw is offline   Reply With Quote
Old 12-25-2015, 07:07 AM   #3
Rewards Points: 3,286
A pebble may have come up a water pipe and jammed the faucet mechansim.
Could you dismantle the faucet from the outside (main cold water turned off of course) and check?
Note: If you dismantle the faucet then you will not be able to return it to the store.
Some single knob tub faucets have screwdriver turned shutoffs against the main body so you don't have to go downstairs to turn off the water. You might check first to be sure they are not partly closed to not give you hot water.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 12-25-2015, 08:18 AM   #4
Retired Moderator
Rewards Points: 7,174
We need to know the brand--However----all of them have an adjustable stop built in so you can prevent scalding----
My guess is the plumber left the setting as the factory had set it---which is almost always to cold.
You will need to remover the handle to adjust the heat---your plumber might come back to adjust it for you---
Or--let us know the brand and one of us will walk you through the adjustment.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (12-25-2015), wcc201 (12-26-2015)
Old 12-25-2015, 09:27 AM   #5
Rewards Points: 1,860
Adjust the scald stop so temperature is between 110 F to 120F.
This is a safety precaution in case one passes out for a medical condition in the shower.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (12-25-2015), oh'mike (12-25-2015)
Old 12-26-2015, 03:28 AM   #6
Rewards Points: 6
Thanks everyone for your help. With your guys help and google search I was able to find a youtube video regarding adjusting the limiters on the delta brand shower I have. Thanks again for all your guys comments. Very much appreciated yall.
The Following User Says Thank You to wcc201 For This Useful Post:
oh'mike (12-26-2015)
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Handle spins on anti-siphon spigot, can't turn water off? gardengirl51 Plumbing 4 10-07-2010 10:34 PM
Hot/Cold water problem in shower 8thebroker8 Plumbing 8 06-30-2010 06:12 PM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 02:12 PM
