Shower Drain To Floor Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2016, 09:27 PM   #1
Rewards Points: 4
Shower drain to floor drain
We had a basement shower over a floor drain,seemed to drain fine. I moved shower to install larger one,the floor drain has p-trap. New shower drain has p-trap and new vent. Now the shower drain runs slow,after shower inch of water in base and takes 15 seconds to clear drain.what went wrong .floor drain p-trap has vent open also only way to drain at all.
5680Beach is offline   Reply With Quote
Old 02-18-2016, 10:14 AM   #2
Rewards Points: 3,268
1. Longer horizontal distance from the new drain location at less than ideal slope even if actual slope meets code?
2. Debris from construction clogging the drain line?
3. New shower is larger so more water accumulated and has to drain?
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 02-18-2016, 11:04 AM   #3
Rewards Points: 4
Shower drain
Thanks, drain is 3 ft.longer,I will check if drain blocked.
Best way to clean out shower drain? Pawl Plumbing 5 03-01-2015 11:27 AM
Adding new shower drain to toilet drain? w layout pics BNR34RB26DETT Plumbing 25 02-11-2015 09:55 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
