Shower Drain - Caulk It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2015, 05:22 PM   #1
Rewards Points: 28
Shower Drain - caulk it?
The black gasket shows on the outside of my fiberglass shower strainer and I'd looks irregular and bad. I'd like to get it 'white'.
Can I put silicone caulk on it? Should I apply it, let it dry and then put the strainer on, or apply it after the strainer?
Should I used something else? I have that previous repair on the side that I wish could look better too.
thank you!
DIYAnnette is offline   Reply With Quote
Old 09-04-2015, 06:24 PM   #2
Rewards Points: 582
thank you!
don't think its a gasket...or it should'ent be...try scratching it to see if it comes out..caulking will only come out because if it is a gasket it will expand and contract from tempeture change..looks like a little bit of mold around it...we install those drains with silicone to seal them...
Old 09-04-2015, 08:47 PM   #3
Rewards Points: 28
I took off the strainer and cleaned outside and inside the drain with a toothbrush and vinegar. I thought I got most gunk off including any mold.
I also felt the black ring with my finger - it felt like rubber. Maybe it was silicone that turned black from mold?
Old 09-04-2015, 09:24 PM   #4
Rewards Points: 1,926
There shouldn't be any gasket there unless an idiot assembled it. The gasket should be on the bottom side of the base.
Old 09-04-2015, 09:43 PM   #5
Rewards Points: 28
Ah. Could the black be glue or sealant? I couldn't clean off some black on the top of the drain body, like it was stained.
(This drain was repaired before I moved in 6 years ago.)
Old 09-04-2015, 10:25 PM   #6
Rewards Points: 582
sure could be the sealant they used....
Shower Drain 325_man Plumbing 9 06-12-2014 06:34 AM
shower drain JP79ST Plumbing 13 05-19-2014 10:54 PM
floor drain to shower drain? The Dogger Plumbing 4 01-30-2013 09:02 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
No Caulk Shower Drain - Leak 9lostboy5 Plumbing 12 03-26-2010 10:00 AM
