Shower Drain In Basement/remodel Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2016, 04:41 PM   #1
Rewards Points: 151
Shower drain in basement/remodel question
Hello all,
I ripped out the shower in our basement that was put in sometime in the 60's. It was ugly, but it was leaking so we have decided to remodel. I'm not sure if I'm going to put in one of those plastic shower stalls or tile it.
My concern is the drain. The base consists of an 1 1/2" to 2" thick concrete pad(poured directly onto concrete basement floor)with tile on top of that. The drain appears to be solid cast iron surrounded by the poured concrete of the basement floor and the base pad. Meaning, I can't move it without ripping up the concrete and I can't adjust the height as far as I know.
If I go with a pre-fab shower stall the drain is off center by about an inch. Being an old style drain I don't even know if I could connect a pre-fab shower stall to the drain. If I decide to tile it I would need to add the rubber barrier and another layer of mortar. Which means I would have to raise the height of the drain. Another option would be to bust out the existing pad and then put the rubber down and mortar that leaving enough drain above so I could tile up to it.
Just looking for options/ideas. Maybe there are parts out there I don't know about to help adapt the old with the new?
I would rather go the pre-fab shower stall route if possible as it will be much faster. Although tiling it would be a fun project too!
Thanks for any help,
Ron
rferoni is offline   Reply With Quote
Old 05-10-2016, 07:36 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Shower drain in basement/remodel question
A picture or two might help---but--you should open the concrete and update the P-trap and set it where you need it---showers require 2" drains--
An electric jack hammer rents for about $65 for a day--unless something odd is below the slab--the concrete chipping ,digging and drain work should only take a few hours.
Old 05-12-2016, 09:57 AM   #3
Rewards Points: 151
Ok. I will break up the concrete. I may just replace the whole cast iron pipe as its not a long run and wouldn't be much more work if I already am started.
Any advice on breaking out the concrete would be appreciated. Jack hammer the only way to go? What about saw-cutting and a sledgehammer? If saw-cutting how deep do I need to cut down? If I want to replace a run of pipe underground should I saw-cut it first so there is a nice even trench width? What about adhering the new concrete to the old?
Thanks,
Ron
Old 05-12-2016, 12:40 PM   #4
Rewards Points: 1,932
You can saw cut but for the little you need seems like a waste of money for a rental.
Adding new shower drain to toilet drain? w layout pics BNR34RB26DETT Plumbing 25 02-11-2015 09:55 PM
Yet another rough in question - connecting drain lines LHB_Texas Plumbing 2 12-28-2014 09:00 PM
Double shower drain vent question. TALDE Plumbing 90 01-20-2014 09:15 PM
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Shower drain location svaic00 Plumbing 4 07-04-2012 06:58 PM
