Shower Door Hinge - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2016, 11:38 PM   #1
Rewards Points: 6
shower door hinge
Hi I have a shower door which is sticky. It wouldn't close clean and every time I have to life it up to close it. I see that there is a gap between the door and plastic. Do I need a new door? Is there a way to fix this issue. Some pictures attached.
Thanks In Advance
Bobby
shower door hinge-img_20161104_184226.jpg   shower door hinge-img_20161103_073629.jpg   shower door hinge-img_20161103_073659.jpg   shower door hinge-img_20161104_184047.jpg   shower door hinge-img_20161104_184057.jpg
abc1234 is offline   Reply With Quote
Old 11-05-2016, 07:53 AM   #2
Rewards Points: 10,416
Re: shower door hinge
What is out of square, the door or the shower framing?
SPS-1 is offline   Reply With Quote
Old 11-05-2016, 08:02 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,400
Is the door square in the frame when it comes to close (i.e. meets the frame square) without lifting it?
There are little phillips head screws that allow you to adjust the square of the door in the frame.
There are also little plastic bushings at the top and bottom of the door that can sometimes be casualties.
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 02:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
