Shower Arm Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2015, 12:39 AM   #1
Rewards Points: 8
shower arm removal
trying to do a few things to my place and i am stuck at removing the shower arm. it doesn't seem like it screwed directly to the wall, possibly a nipple?
been spraying WD40 to help loosen it up, but cannot remove the shower arm , and dont want to apply too much pressure to make things worse
do i need to remove the shower arm first?
or can i remove the nipple looking thing?
would a pipe wrench make things easier?
any tips would help, thanks!
some pics
http://uploads.im/fU9pC.jpg
http://uploads.im/4vniA.jpg
Energy48 is offline   Reply With Quote
Old 01-05-2015, 04:42 AM   #2
Retired Moderator
Rewards Points: 7,174
I've never seen anything like that---sorry--some else might know.
Old 01-05-2015, 04:57 AM   #3
Rewards Points: 2,528
That looks like a reducing bushing. Dont know why someone would have to use a reducing bushing for a shower arm but thats my guess.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
oh'mike (01-05-2015)
Old 01-05-2015, 06:32 AM   #4
Rewards Points: 6,286
2 pipe wrenches 180 to each other.
Old 01-05-2015, 09:46 AM   #5
Rewards Points: 18,952
Is that threads on the outside of that old steel pipe sticking out of the wall?
Looks like someone threaded the inside of a steel pipe nipple to me.
May be opening up a can of worms trying to remove that arm.
Old 01-05-2015, 10:57 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 240
I have never used one, but that looks like a retro fit shower ell.
They are used when there is no backing to anchor a standard drop ear 90 in the wall.
An escutcheon screws onto the outer threads to sandwich the backerboard/drywall to make a rigid mounting for the arm. This is just a guess....
I usually remove arms by inserting a handle of my channel locks into the nipple(like a cheater bar) and twist- while supporting the 90 with my free hand
Same goes for reassembly..
Old 01-05-2015, 02:46 PM   #7
Rewards Points: 8
Thanks for the responses
It seems like it's screwed into the wall and the arm is screwed into it.
I may try the pipe wrench since I just want to get rid of the arm. Hopefully it won't be a can of worms.
I tried the arm of pliers inside the arm, but either I m not doing it right or its just too stuck. I can't get the arm of the pliers to stay in place when trying to unscrew.
Shower handle removal eanda Plumbing 6 12-03-2014 09:47 PM
Help with shower pan removal - 1960s bath jm71 Kitchen & Bath Remodeling 6 11-23-2009 07:54 PM
shower knob removal mnemnoch Plumbing 1 03-02-2009 04:21 PM
Removal of shower doors/frame proofer Plumbing 8 08-16-2008 10:33 AM
glass shower door removal ross General DIY Discussions 1 04-25-2005 06:22 AM
