Should I Replace This Overflow Tube (flush Valve)? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2016, 09:49 AM   #1
Rav
Rewards Points: 892
Should I replace this overflow tube (flush valve)?
See attached pic. When I was flushing out the fill valve in this toilet, I noticed that the overflow tube has a crack and a chunk missing at the top. It's probably been like this for a while. The water level is well below the problem area. Would it be advisable to replace the flush valve and overflow tube now, or wait until it gets worse or actually starts leaking? Thanks.
Rav is offline   Reply With Quote
Old 06-02-2016, 11:42 AM   #2
JUSTA MEMBER
Rewards Points: 3,254
Re: Should I replace this overflow tube (flush valve)?
As long as no one messes with it , it should last quite a while.
Those used to be made from brass, yours looks to be plastic.
It was broken by whomever was trying to clip the small tube onto it.
ED
de-nagorg is online now   Reply With Quote
The Following 2 Users Say Thank You to de-nagorg For This Useful Post:
Rav (06-02-2016), SHR Plumber (06-03-2016)
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Do I need to replace this Flow Control Valve? houseright HVAC 4 01-31-2015 02:14 PM
Need to replace leaky valve dariusld Plumbing 16 12-11-2013 07:03 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
