Should I Replace Or Clean This Supply Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-10-2017, 10:00 AM   #1
Rewards Points: 118
Should i replace or clean this supply pipe?
Moved into this house about a year ago, and it was bank owned/vacant for something like 4 years.
I just plumbed in a whole house filter(a single big blue) and while doing so i noted the copper pipe had a brownish/black coating inside which could be rubbed off with my pinky. From where i did the work, the supply line travels about 25' or so horizontal before it branches off.
Would you replace that horizontal line? it's easy work given the open access, but wanted to see if i'm over-thinking the concern. Or, i could give it a cleaning: tie a 3/8 nut to a fishing line and pull that through with a damp cloth.
DarrenLevine is offline   Reply With Quote
Old 10-10-2017, 10:22 AM   #2
Rewards Points: 2,632
Re: Should i replace or clean this supply pipe?
I believe that is normal oxidation.
bob22 is online now   Reply With Quote
Old 10-10-2017, 10:31 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,930
I would not.
Old 10-12-2017, 06:45 AM   #4
Rewards Points: 18
If you are going to replace it, I would suggest using PEX rather than copper. Cheaper and easier.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 10-12-2017, 06:35 PM   #5
Rewards Points: 1,930
Leave it alone. That is a biological film that is present on all old water lines. It actually helps eliminate lead in your drinking water from the solder joints. It's a good slime. :}
Ghostmaker is online now   Reply With Quote
Old 10-24-2017, 04:55 PM   #6
Rewards Points: 118
Loud and clear, thanks all for saving me time and $$$
Small-to-large supply pipe? Tom738 Plumbing 1 11-27-2014 08:03 AM
HDPE water pipe - How to clean prior to caulking goshenplumber Plumbing 2 05-31-2014 08:15 AM
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
Poly Gasline to replace Black Pipe? GabeD Plumbing 9 08-29-2010 11:47 AM
protruding shower drain and supply pipe mooseofplenty Plumbing 2 07-21-2010 11:45 PM
