Shortest Run For Pex Allowed? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2016, 09:30 AM   #1
Rewards Points: 192
Shortest run for pex allowed?
Is there a standard for length of pex? I am asking because under my sink there is a shut off for an outside water spigot. There is a short piece of pex from The shut off to a shark bite 90
I'm worried that this 2 inch piece of pex may fail overtime because it's so short.. Am I just paranoid?Shortest run for pex allowed?-imageuploadedbytapatalk1453649411.868259.jpg
badhaircut is offline   Reply With Quote
Old 01-24-2016, 09:34 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 188
Yep, you're just paranoid. Don't loose sleep over it
The Following User Says Thank You to TheEplumber For This Useful Post:
badhaircut (01-24-2016)
Old 01-24-2016, 09:35 AM   #3
firehawkmph's Avatar
Rewards Points: 2,582
Yes, you're just paranoid. It's not leaking, it's not broke, leave it alone.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Old 01-24-2016, 09:38 AM   #4
Rewards Points: 582
on our wirsbo system smallest piece of pipe is 2" we use a ton of them, infact we have made up a tray 2" nipples for all the trucks ...you will be fine
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 01-24-2016, 09:58 AM   #5
Rewards Points: 192
Thank you all
Old 01-24-2016, 10:27 AM   #6
Rewards Points: 582
all of us say welcome
firehawkmph (01-24-2016)
UF-B allowed in place of public assembly? GregBaz Electrical 19 10-27-2014 11:11 PM
Toilet drystack - how close, what angles allowed? weekendwarrior9 Plumbing 16 10-09-2012 10:03 PM
relocating older 220 dryer outlet: what is allowed? rasz Electrical 4 06-27-2012 08:29 AM
Total conducters allowed in a device box zigfried Electrical 7 06-02-2012 09:03 AM
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 12:28 AM
