Sharkbites - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2014, 09:14 AM   #1
Rewards Points: 32
Sharkbites
I've read some of the forums out there and the consensus seems to be sharkbites are pretty darn good.
I'm doing a partial remodel and I'm going to have to be moving water lines and drains. I was thinking about using sharkbites on the existing copper then going to PEX, for the ease of use. Do you recommend?
Thanks!
slg1285 is offline   Reply With Quote
Old 11-23-2014, 09:20 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,702
Originally Posted by slg1285 View Post
the consensus seems to be sharkbites (can be) pretty darn good.
In the right circumstances... like unplanned repair work.
I'm doing a partial remodel ...Do you recommend?
Nope. Not for **planned** work.
If you don't know how to sweat copper... use this as a way to learn.
If you do know how... the cost is lower with sweat fittings.
TarheelTerp is online now   Reply With Quote
The Following 2 Users Say Thank You to TarheelTerp For This Useful Post:
BlackTiger (11-26-2014), Javiles (11-27-2014)
Old 11-23-2014, 11:01 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,302
Ayuh,.... Agreed,.... Shark-bites are Great, for a quick fix, or for a fittin' ya can't get close enough to, to solder,...
No way I'd use 'em, for everyday plumbin',.... Tooooo expensive,...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
Old 11-26-2014, 03:01 PM   #4
Rewards Points: 56
If soldering cannot be preformed due to confined space or swiveling is needed, sharkbites. Otherwise, save your money!
CluckingChicken is offline   Reply With Quote
Old 11-27-2014, 01:30 AM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Shark bites are good for "quick" fixes AND long term use.
If cost is not an issue for you and time is, the shark bites are the way to go.
sublime2 is offline   Reply With Quote
Old 11-27-2014, 10:44 AM   #6
Rewards Points: 38
I have posted my support of Sharkbite-brand fittings numerous times but I disagree with this quote. Sharkbite-brand fittings are great for small or temporary repairs when a more permanent solution is not viable at the moment. Use permanent fittings for a professional quality plumbing job.
SHR Plumber is offline   Reply With Quote
Old 11-27-2014, 11:39 AM   #7
Civil Engineer
Rewards Points: 5,246
Shark bites are also useful as a means to provide a disconnect in a PEX run, similar to what a union does for copper piping. I have two sharkbites in my house, one provides a disconnect on the downstream side of the well T, and one provides a disconnect on the cold water inlet to the water heater. The shark bite on the well water line has been in place for 8 years with no issues, the one on the water heater has been in for 5 years with no issues.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
sublime2 (11-27-2014)
Old 11-27-2014, 02:47 PM   #8
Rewards Points: 599
Well, I've completed two bathroom remodels with them, behind the wall, and am now into year 8 on one (might have been a "Gatorbite") and year 4 on the other with no problems. I also see why a professional would prefer copper and if I had those everyday skills, I would have used copper as well. But for a homeowner who can do all the other work required except the copper --- weigh the cost between using them and calling a professional out to do the work, I'll go with the homeowner product.
Curmudgeon10 is offline   Reply With Quote
Old 11-27-2014, 04:43 PM   #9
If it's not soldered you can't trust it. It's quick to clean, paste and sweat a joint. Much cheaper also
gassyplumber is offline   Reply With Quote
Old 11-27-2014, 06:24 PM   #10
Rewards Points: 1,948
Any one can glue CPVC waterlines. Permanent and cheap.
Old 11-27-2014, 06:32 PM   #11
I have never seen a cpvc water line. Copper, pex , threaded brass and old school galvy are all I have ever dealt with.
Old 11-27-2014, 06:54 PM   #12
CPVC been out for a while now. You use one step glue its the yellow cpvc glue and go to it. Run it just like copper. Just use plastic straps. No special tools... Give it an hour or 2 to dry and your done.
Old 11-27-2014, 07:20 PM   #13
Rewards Points: 32
I'm not worry about sweating fittings, but (sorry plumbers) I think pex is better. Thank you all for the input
Old 11-27-2014, 09:18 PM   #14
Davejss's Avatar
Rewards Points: 1,072
Old school BS. You can trust Sharkbites. Fittings like Sharkbites have been in use for many years. One of these days soon, soldering will have gone the way of the buggy whip.
Davejss is offline   Reply With Quote
Old 11-27-2014, 11:06 PM   #15
I'll believe that after seeing it 75 years from now.
Sharkbites on copper? Kyle_in_rure Plumbing 2 01-19-2014 03:45 PM
Sharkbite fittings on PB pipe rjniles Plumbing 17 08-16-2011 01:33 PM
When using Sharkbites, how do you attach toilet shut offs? medicmike Plumbing 5 01-27-2010 11:48 PM
Pex shower rough in valve, what goes to the shower section? twilightcall Plumbing 23 08-09-2009 06:37 PM
How to join new pex to old copper? Nitro Plumbing 7 10-19-2007 09:47 AM
