Sharkbite Coupling Failure - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By chandler48
Old 08-18-2017, 07:28 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Sharkbite coupling failure
Got a call from a friend that he had a leak at his water heater at the supply shut off valve. This is a WH I installed for him about a year ago. I had cut the copper at the shut off and installed a Sharkbite coupling on the copper stub and transitioned to PEX to the WH. He had shut off the valve and when I turned it on the water sprayed out at the copper side of the coupling. I could see the insertion mark I had made on the copper and it was obvious that the coupling had slipped and the copper was barely inserted into the coupling. I pushed the coupling back onto the copper and the leak stopped. I then pulled the joint and the coupling pulled totally off the copper stub. WTF! I then took a new Sharkbite , removed the old, cleaned up the stub and installed the new coupling insuring it was fully inserted. Gave it a pull and and the new coupling pulled off the copper stub.
I have used Sharkbites in the past and never had an issue. In fact my own WH is plumbed exactly the same way and has been there for 7 years.
Any way, I removed the Sharkbites from both copper stubs, sweated on male adapters and used PEX female adapters to transition to the PEX.
Still mystified. Is it possible the copper was undersized? Friends house is about 30 years old and this is the third or fourth WH.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 08-18-2017, 09:58 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,532
Re: Sharkbite coupling failure
Could it possibly have been soft copper rather than hard? Not sure if the OD is different, but that is an anomaly for sure. I do note that on sharkbite fittings they come with tan plastic rings and bluish gray rings. The latter ones are for Polybutylene only, and will not fit copper/pex/cpvc. They blow off almost immediately.
MTN REMODEL LLC likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-19-2017, 08:13 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
Definitely hard copper and the tan plastic Sharkbites. I just looked at the Sharkbites I removed and the internal teeth do not seem to seem to protrude as much as others in my parts box. Wondering if I had defective couplings.
Old 08-19-2017, 09:43 AM   #4
Naildriver
chandler48's Avatar
Could be. I bet Sharkbite/PEX would be interested in seeing that just in case there should be a recall or something.
Mike Milam likes this.
Larry......
Old 08-19-2017, 10:01 PM   #5
Rewards Points: 1,066
I don't use Sharkbites after seeing a couple fail.
NotyeruncleBob is offline   Reply With Quote
Lennox G40UH furnace stops and fails to start at nights only Muscovite HVAC 20 03-12-2014 01:44 PM
Sharkbite Fittings davidblackwoods Plumbing 55 06-14-2013 08:14 PM
Dresser coupling with galvanized pipe shnaig Plumbing 10 05-02-2012 09:25 PM
Using a rubber coupling instead of PVC coupling sukhenkoi Plumbing 2 04-05-2011 06:53 AM
