Sewer Woes - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2016, 06:15 PM   #1
Rewards Points: 8
sewer woes
we have a sewer clog and while we are figuring out how to fix it, it is backing up into floor drain...the problem we can't figure out is that when it backs up through floor drain it also seeps through small cracks in foundation (old house) at opposite side of basement...does this mean there is a crack somewhere in pipe and is leaking under house?
globill is offline   Reply With Quote
Old 02-04-2016, 06:23 PM   #2
Property Mgt/Maint
Rewards Points: 8,184
Need to snake the main line leading away from the house. There should be a clean out for snake entry just prior to exiting thru the wall.
Do you have a septic tank or municipal sewer?
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
globill (02-05-2016)
Old 02-04-2016, 06:29 PM   #3
Rewards Points: 18,784
Could be lot's of things.
"Old pipes" could be , cast iron, orange burge pipes.
Roots growing into the drains?
Time to call in a real plumber and have them snake the the drains a run a camera down the lines to see what's going on.
Old 02-04-2016, 06:31 PM   #4
Rewards Points: 582
old terracotta pipe when clogged leaked ..have line snaked out and camera run to inspect it..
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 02-04-2016, 10:04 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 31,624
If your house is like mine the sewer line also picks up the water from the weeping tiles. If the main line is blocked the water will also back up and fill all the tiles around the outside of your foundation. Any weak spots in the foundation will let the water in.
Care guess how I know about this.
The Following User Says Thank You to joed For This Useful Post:
Old 02-05-2016, 09:14 AM   #6
Rewards Points: 8
It is an old house and does not have weeping tiles...we had it scoped once and though they mentioned blockage and tried to clear it (mortar debris) unsuccessfully they never mentioned a crack in the line and do not seem to want to answer my questions as to why it is leaking on far corner only tells me I need a weeping tile expert....we are at a loss as to whether to try more things to unclog line (a chain knocker was suggested) or take our losses (have spent about $500 so far) and dig up line.
Old 02-05-2016, 09:35 AM   #7
Super Moderator
joed's Avatar
I guess that means dig it.
Old 02-05-2016, 10:46 AM   #8
Rewards Points: 8
was afraid of that !!
Old 02-05-2016, 10:47 AM   #9
Rewards Points: 8
on municipal sewer
Old 02-05-2016, 12:04 PM   #10
WhatRnsdownhill's Avatar
Rewards Points: 2,220
for the most part you own the sewer line out to the street where it ties into the spur on the municipal sewer line...
WhatRnsdownhill is offline   Reply With Quote
Old 02-05-2016, 01:35 PM   #11
Super Moderator
joed's Avatar
Depends on the town. In my city we only to deal with to the property edge. The city takes care of the rest from the line to the sewer.
Old 02-05-2016, 05:58 PM   #12
Rewards Points: 1,856
Contact your local sewer authroity and find out exactly what you are responsible for and when the become responsible. I have seen up house to test tee home owner, and also house to sewer tie in under street home owner. Street repair on your bill.
Water backup into basement floor drain after jetting lateral and sanitary sewer sm2327 Plumbing 4 04-01-2013 12:18 PM
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
