Sewer Pipe In Basement Wet In Between Crack - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2016, 06:31 PM   #1
Rewards Points: 2
Sewer pipe in basement wet in between crack
Every time it rains a lot our sewer pipe in the basement gets water build up in between the crack or joint where it connects to the other piece of pipe. Here's a pic not sure if you can tell where the water is from pic. It doesn't overflow, but what could be the reason for this?
Sewer pipe in basement wet in between crack-img_3203_1478129456125.jpg   Sewer pipe in basement wet in between crack-img_3204_1478129477479.jpg
Mkr88x is offline   Reply With Quote
Old 11-02-2016, 08:24 PM   #2
Rewards Points: 18,772
Re: Sewer pipe in basement wet in between crack
That top pipe run all the way to roof as a vent?
If so get up on the roof and check the roof jack to see if the seal has failed.
Simple 10 min. about $7.00 fix if that's it.
Old 11-02-2016, 08:24 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,304
If it's not tied to drainage, it's most likely the condensation from additional humidity or a vent boot leak as Joe said.
Old 11-03-2016, 05:11 AM   #4
Rewards Points: 2
Yea it's the one that runs all the way to the roof. I'll have to get up there and check it out
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Basement sewer pipe set in concrete wall leelman Plumbing 4 03-15-2012 08:26 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
