Sewer Gas Smell In House - Frozen Vent Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2015, 12:36 PM   #1
Just call me Andrew
Rewards Points: 1,040
Sewer gas smell in house - frozen vent pipe?
Hello,
My friend's bathroom has been smelling, on and off, like sewer gases. We're in upstate NY, and there's at least 2.5 feet of snow on the ground. My thought is that maybe the vent pipe is clogged or iced over, and traps are getting sucked dry due to the lack of venting.
Short of getting on the roof, any recommendations? Would heating the bottom of the vent pipe in the basement possibly send enough heat up the pipe?
Would it make sence to instal a cleanout at the bottom of the vent pipe, so we could remove the cap and blow hot air right up the pipe?
Thoughts?
Andrew
secutanudu is offline   Reply With Quote
Old 02-14-2015, 12:38 PM   #2
Rewards Points: 1,932
Add water to all your fixtures and wait for a thaw. Do it every time you flush.
Ghostmaker is online now   Reply With Quote
Old 02-14-2015, 12:43 PM   #3
Just call me Andrew
That's just what she's been doing
Andrew
Old 02-14-2015, 12:43 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,940
If the vent is clogged you should here gurgling from the fixtures when water is used in another fixture as the water is sucked out of the drain.
Another possibility could be a bad seal around the bottom of the toilet or a dried out trap somewhere that is not being used like the basement.
Old 02-14-2015, 12:57 PM   #5
Rewards Points: 2
Tub and toilet don't drain
I have 4 sets of plumbing in my converted barn that were installed at different times. The 4th and newest is not finished. The oldest (1st section plumbing, toilet, tub, and sink), is backing up, not draining. The 2nd section is working fine. We are in upstate NY and it has been unusually cold. We suspect there's a problem with the drainage pipe, where the newest section connects to the oldest section.
CarlFal is offline   Reply With Quote
Old 02-14-2015, 02:14 PM   #6
Rewards Points: 3,430
Originally Posted by secutanudu View Post
Hello,
Thoughts?
Just a thought. If the roof vent is covered with snow, try using an extra long roof rake from the ground to uncover it.
Can you see the roof vent at all?
jmon is offline   Reply With Quote
Old 02-14-2015, 02:17 PM   #7
PoleCat's Avatar
Rewards Points: 1,658
Have someone drain a sink load of hot water while you observe your vent stack from outside. You will quickly know it your vent is frozen shut or there is a new pope.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
jmon (02-14-2015)
Old 02-14-2015, 02:28 PM   #8
Do we need a new pope?
Old 02-15-2015, 09:31 AM   #9
Rewards Points: 352
Don't hijack other peoples thread, start your own.
plumberinlaw is offline   Reply With Quote
Old House Smell and Cigarette Smell and Zinnser BIN jpfulton248 Painting 10 06-02-2013 08:57 AM
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 12:23 PM
Distance from vent pipe to clean out? toddmanqa Plumbing 2 03-24-2012 01:41 PM
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
Frozen Septic Sewer Pipe. econdave Plumbing 11 03-15-2008 05:00 PM
