Sewage Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2016, 11:00 AM   #1
Rewards Points: 1,128
Sewage smell
We had a toilet Added to our ground floor laundry room about a year ago. He tapped into the main line and also pipe our washer machine into the main line so as to drain into cesspool and not dry well. From what we remember we've never smelled a foul order but I changed out the toilet bowl about 2 months ago and we've been smelling poop amd sewage since then. I do t know how m changing out the bowl could cause this. I put the wax seal on correctly. I'm thinking there is a venting issue but like I said I believe the smell was not there prior to me installing new bowl although I could not be remembering. Would of he had to do something for venting when installing the toilet bowl and tying into the main line?
We did have our cesspool pumped and main line cleared as there was a clog and this also happened a few months ago. Could it be something at the trap? Any suggestions would be great. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 12-10-2016, 04:59 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,408
Re: Sewage smell
How was it "tapped" into?
Might not have a proper trap. That is problematic.
Old 12-11-2016, 10:51 AM   #3
Rewards Points: 1,054
Re: Sewage smell
The toilet is the trap. There must be something wrong past the toilet, or a flange sealing issue.
clarenceboddick is offline   Reply With Quote
Old 12-11-2016, 11:10 AM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Re: Sewage smell
X2 on the gap in your wax seal.
123pugsy is offline   Reply With Quote
Old 12-11-2016, 11:16 AM   #5
Rewards Points: 5,590
Re: Sewage smell
To determine if the wax ring is leaking gas, put your nose to within an inch of the toilet base and floor junction and you'll quickly be able to determine if the ring is leaking gas because you will experience a stronger odor there. It's called the poor boy sniffer method but it works.
Old 12-11-2016, 11:50 AM   #6
Thank you everyone. I'll let you know what I find.
Persistent Burning Smell for Over 18 Months Lynn333 HVAC 21 01-24-2016 11:35 AM
Help: Sewage smell coming from shower drain! erikerikerik Plumbing 23 01-11-2014 02:09 AM
sewage smell and and history of backup in floor drains jeffzap Plumbing 14 03-17-2013 11:29 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Sewage smell jimh Plumbing 7 03-01-2010 04:50 PM
