Sewage Pump Water Level - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2015, 07:29 PM   #1
Rewards Points: 34
Sewage pump water level
I just installed a new .6 HP sewage pump in my homes ejector pit. The pump has a tethered float. The only concern is the pit fills with quite a bit of water before the float is activated. The height of the water reaches at least halfway up the 4 inch drain that's filling the pit. Is this a potential problem?
Phickman1 is offline   Reply With Quote
Old 12-19-2015, 08:37 PM   #2
Rewards Points: 1,866
Pump should fire before water hits bottom of the incoming pipe.
Old 12-21-2015, 10:08 AM   #3
Rewards Points: 34
The tethered float is attached to the top of the pump with a screw and plastic clip. Is there a good way to remove this method and attach the line at a lower level on the pump or pvc so the pump activates sooner? I shortened the line but still not kicking on early enough for my liking.
Recent flood-water was gushing through crawl-space foundation where sewage pipe exits DanDaMan Plumbing 5 07-20-2015 02:25 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Sump Pump Water Level w/inside Drain Tile scott j Plumbing 1 02-18-2011 10:25 PM
booster pump/ water pressure problem harpua103 Plumbing 3 12-30-2009 03:26 PM
Sump pump pit water level Ralph123 Building & Construction 6 07-24-2008 05:33 AM
