Sewage Ejector Pump - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 09-28-2016, 04:48 PM   #16
Rewards Points: 964
Re: Sewage Ejector Pump
Rigid is special order. They do carry Wayne, which appears to be the maker or Rigid. Rigid reviews aren't great, but yes, I had good luck with mine. Wayne appears to get good reviews.
I'm trying to figure out which Zoeller pump might fit my specs and I won't argue their quality, I've heard that, but are they worth 50% more...maybe almost double? I will say if it lasts twice as long, it's worth it as the fewer times I have to open up a sewer system the better!!
Master Brian is offline   Reply With Quote
Old 09-29-2016, 06:44 AM   #17
SHEPLMBR's Avatar
Rewards Points: 178
For a sewage pit in basement it would be the model 267. And if you are having on goning float problems, get the non-auto and a separate piggy back switch. one that you plug in then plug the pump into.
SHE-PLMBR
SHEPLMBR is offline   Reply With Quote
Leaky Sewage Basin Weakend Warrior Plumbing 12 04-23-2017 10:05 AM
Recent flood-water was gushing through crawl-space foundation where sewage pipe exits DanDaMan Plumbing 5 07-20-2015 02:25 PM
Sewage ejector pump question Jdbrooks Plumbing 5 04-23-2013 07:38 AM
Can I pump sewage ejector pump into horizontal clean out? mnschu Plumbing 10 01-31-2012 06:11 PM
Plumbing a sewage ejector pump noviceguy Plumbing 3 03-11-2011 09:59 AM
