Sewage Ejection Pump Sucks Water Out Of Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By hkstroud
Old 01-04-2018, 03:37 PM   #1
Rewards Points: 92
sewage ejection pump sucks water out of toilet
Just noticed for the past several weeks, every time when my sewage ejection pump in the basement is running, the water in the toilet bowl get sucked out. This happens to all three toilets in my house, from basement to 2nd fl. My first response is blocked vent. But I do not have drainage issue so far (knock on wood). The shower, sinks are fine. It is snowy and cold in MA now, so I don't know if I can go up to the roof to check. Any suggestions? Thanks.
shiyang100 is offline   Reply With Quote
Old 01-04-2018, 04:33 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 882
Re: sewage ejection pump sucks water out of toilet
I agree, blocked vent. May be snowed in and/or frozen.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 01-04-2018, 04:38 PM   #3
Rewards Points: 898
Do you have a vent coming off the lift tank?
BIG Johnson is offline   Reply With Quote
Old 01-04-2018, 04:41 PM   #4
Guapo
Rewards Points: 11,950
Do all three toilets go to the ejector pump? Usually only the lowest toilet needs the pump.
Guap0_ is offline   Reply With Quote
Old 01-04-2018, 05:07 PM   #5
Rewards Points: 92
yes, only the lowest toilet in the basement connects to the sewage ejection pump. But when it is on, all three toilets lose water. Feel like a strong vacuum suck the water out. But I can bring water level in the bowl back to normal by just flushing the toilet.
Old 01-04-2018, 05:37 PM   #6
Rewards Points: 1,928
May I suggest you stop using the lower basement level until it warms up for the vent to thaw?
Old 01-04-2018, 05:46 PM   #7
hkstroud's Avatar
Rewards Points: 6,694
The sewage ejection pit should have its own separate vent pipe. That is probably where the blockage is.
Guap0_ likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 01-04-2018, 05:58 PM   #8
Rewards Points: 92
we don't use basement now. The water is from the condensation from two furnaces. So the pump only runs every several days.
Old 01-04-2018, 06:07 PM   #9
Super Moderator
joed's Avatar
Rewards Points: 31,924
I agree with the others. The vent is clogged. When the water is pumped out, air needs to be able to enter the tank/pit. If the vent is clogged then it will suck from the next easiest point, which is your toilets.
Old 01-04-2018, 06:26 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 2,030
Another vote for a blocked or restricted vent. The ejector pump pushes water faster than regular gravity fixtures which may explain why they work ok and why it may just be restricted with snow or ice.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Toilet water hammer noise no come only when hot water is running at sink why? daluu Plumbing 0 08-24-2014 11:41 PM
sewage pump high water alarm tessrea Plumbing 8 09-11-2011 01:59 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
