Sewage Basin - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree13Likes
Old 11-27-2019, 11:52 AM   #1
Rewards Points: 192
Sewage Basin
I am dry fitting the sewage basin. Based on the position of the discharge line and the hole in the basin, this is what I am ending up with. The basin is protruding about 4 inches above the floor. Is this normal or shoud I find a way to lower the discharge line?
Appreciate your advice.
CanadianSal is offline   Reply With Quote
Old 11-27-2019, 06:10 PM   #2
Rewards Points: 1,620
Re: Sewage Basin
dig deeper
Old 11-27-2019, 06:19 PM   #3
retired framer
Rewards Points: 5,788
Re: Sewage Basin
Your sewer line is right below the floor? Is that the port you want to run the toilet line in?
Do not use flat bottom gables with scissor trusses.
Old 11-27-2019, 06:20 PM   #4
Rewards Points: 192
Re: Sewage Basin
Originally Posted by Ghostmaker View Post
dig deeper
No digging deeper wil not help - the hole is already lined up on the side. If I go deeper then I will have to drop the pipe lower under the concrete.
Old 11-27-2019, 06:26 PM   #5
Rewards Points: 192
Re: Sewage Basin
[QUOTE=Nealtw;5992873]Your sewer line is right below the floor? Is that the port you want to run the toilet line in?[/QUOTE
So the toilet and shower discharge is under the floor. They empty into the basin. So right now the hole in the side of the basin and the discharge line is lined up. Does that clear it up?
So it looks like I have to lower the discharge line (the inlet) or leave the basin sticking out?
Old 11-27-2019, 06:35 PM   #6
retired framer
Re: Sewage Basin
[quote=CanadianSal;5992885]
Usually you would place the basin first and plumb to that?
Do you have it in a place where a raised floor would work?
Old 11-27-2019, 06:38 PM   #7
retired framer
Re: Sewage Basin
dig deeper
Would you just add elbows to get his drains low enough?
Old 11-27-2019, 06:41 PM   #8
Rewards Points: 192
Re: Sewage Basin
[quote=Nealtw;5992891]
Hope the picture helps. This is a roughed in pioe under the concrete. I am now trying to insiall the basin. The circled area shows the pipe in the current location - thats along the side of the pit about 3 inches under the floor. So If I want the Basin level to the floor, we lose this alignment.
Old 11-27-2019, 06:49 PM   #9
retired framer
Re: Sewage Basin
[quote=CanadianSal;5992895]
This is what I would look at.
Old 11-27-2019, 06:50 PM   #10
Rewards Points: 192
Re: Sewage Basin
Thanks - I will look into this - not sure I will have enough space in the pit. There is only about 4 inches of wiggle room.
Old 11-27-2019, 06:53 PM   #11
retired framer
Re: Sewage Basin
It sounds easy if you say if fast.
Old 11-27-2019, 07:20 PM   #12
Property Mgt/Maint
Rewards Points: 7,562
Re: Sewage Basin
Curious, did you cut the hole in the basin?
[political signature removed]
Yodaman is online now   Reply With Quote
Old 11-27-2019, 08:05 PM   #13
Rewards Points: 192
Re: Sewage Basin
No - they are sold like this. Would adding a layer of concrete around the basin be a possible solution?
Old 11-28-2019, 06:45 AM   #14
Property Mgt/Maint
Re: Sewage Basin
Personally I see no problem with leaving the basin top above the floor line, other than unsightly.
And as far as adding concrete around it, should do a good job of protecting it.
Or, cutting the protruding riser may be a option, but you would likely need a different top. The MFG may have a top that seals on the I.D. of the riser in lieu of the current flange.
Old 11-28-2019, 07:02 AM   #15
A "Handy Husband"
rjniles's Avatar
Rewards Points: 218
Re: Sewage Basin
Close up theprecut hole and cut anew one closer to the top of the sump.
Sent from my RCT6A03W13E using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
