Service Cast Iron Adapter Confusion - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By paul100
Old 09-23-2016, 10:07 PM   #1
Rewards Points: 14
I'm adding a drain connection to a 110 year old stack which I've determined is a 4 inch "service" cast iron pipe (outer diameter 4.3"). I need to couple a 4" Schedule 40 PVC pipe to it, but that has a 4.5" outer diameter.
Obviously the standard 4 x 4 Fernco flex couple won't do the job, and I've been scratching my head on how to do this. I came across this other Fernco product for service weight C.I. pipes (Multi-Tite):
https://www.fernco.com/plumbing/donu...e-pipe-gaskets
I'm confused about how this works. I would assume I need the 4 x 4 variant (SVG-4) and I'm guessing I need to shove the donut into the cast iron. But on inspection of a unit at Home Depot, I found that a 4" PVC pipe fit inside the top opening, but the other end looked like it would be way too big to fit into the cast iron. If I use brute force, won't that distort the ring and lead to blockages?
And assuming I figure out how to use this thing, do I then need a standard 4x4 Fernco on top of everything?
Thanks in advance for any guidance on this
delawhere is offline   Reply With Quote
Old 09-23-2016, 10:50 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 162
Re: Service Cast Iron Adapter Confusion
The gasket doughnut you show goes in the hub of cast iron. A transition coupling is needed to join plain end pipes together. Are working with a hub on the cast iron?
Old 09-23-2016, 11:40 PM   #3
Rewards Points: 14
Gotcha, so that's supposed to go into the hub. Working with the hub will not be possible for me, I'll be sawing the pipe and working on the cast iron.
What are my options?
Old 09-24-2016, 06:39 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,584
No hub couplers, commonly called Ferncos after the brand name.
Old 09-24-2016, 08:27 AM   #5
Plumber
Rewards Points: 162
https://www.fernco.com/plumbing/shie...flex-couplings
Old 09-24-2016, 10:12 AM   #6
Rewards Points: 14
Thanks for the tip, so are these shielded couplings standard for transitions between differing diameters? Just want to make sure that the .2" reduction going down isn't going to result in an unfortunate "incident"
Old 09-24-2016, 05:01 PM   #7
Rewards Points: 1,848
Proflex brand transitional coupling is the name fernco uses. Buy CI to PL on the label.
Another is mission brand .
Old 09-26-2016, 02:33 PM   #8
Rewards Points: 14
as long as it's a tight seal with the bigger diameter pipe sitting on top of the smaller diameter pipe (4.5" OD --> 4.3" OD)
Old 09-26-2016, 04:11 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
The ID is 4" on both
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 09-26-2016, 07:58 PM   #10
Rewards Points: 2
looking at this site you need part number 3000-44. that will connect service CI to plastic for 4". https://www.fernco.com/plumbing/shie...flex-couplings
SHEPLMBR likes this.
paul100 is offline   Reply With Quote
Old 09-26-2016, 11:16 PM   #11
Rewards Points: 14
Thanks Paul, wasn't sure about the diameters. I'll go ahead and order a couple of 3000-44 units
PVC to Cast Iron circa 1985 Perry401 Plumbing 4 07-15-2013 02:09 PM
4" cast iron to pvc hub jonnyz Plumbing 11 01-01-2013 10:02 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
replacing/altering cast iron supply & return lines? jeffro83 HVAC 5 05-12-2011 06:14 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
