Septic: Will Someone Read This Sludge Stick? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-21-2015, 04:24 PM   #1
Rewards Points: 106
septic: will someone read this sludge stick?
I followed instrux to "...wrap cloth around a stick, mark 6", 1', 2', etc. to create your sludge stick. Drop it down, wiggle it around to make sure it's good and bottomed out though all the sludge." I followed the intrux to hold the stick in the tank for a minimum of 5 minutes before pulling it out. I would appreciate another opinion on what the sludge level is for our septic from this picture.
Also: what is the 26" manhole cover in the 2nd picture accessing (the primary chamber)? if so, where is the input baffle? The septic records say it's a 2 chamber tank. It's a gravity system ... probably 1150 gallons. The manhole cover is 109" from the house.
The small green lid leads to the output baffle which contains the filter. The 26" manhole cover doesn't seem to contain a baffle .... so where is the input baffle?
septic: will someone read this sludge stick?-sludge-slick.jpg   septic: will someone read this sludge stick?-manhole-cover-output-baffle.jpg
Nospammer is offline   Reply With Quote
Old 05-21-2015, 10:47 PM   #2
JUSTA MEMBER
Rewards Points: 3,914
Without more detail on your stick, I cannot tell you what the depth is.
The 26 inch cover is a cover for the inspection and clean out of the tank by a person.
The small hole is for the vac truck to pump out the tank periodically.
ED
de-nagorg is online now   Reply With Quote
Tags
septic , sludge stick
Handy tips for a happy house-- oh'mike General DIY Discussions 67 05-11-2014 07:39 PM
self stick vinyl tiles frank10 Flooring 1 03-27-2013 10:36 AM
Peel and stick on painted concrete? polarzak Flooring 8 12-23-2011 01:13 PM
septic emergency? help! denemante Plumbing 47 11-21-2011 01:05 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
