Septic Tank Aerator - Need Some Advice - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Lawrosa
Old 06-01-2016, 02:23 PM   #1
Rewards Points: 2
Hey Folks!
I purchased a home at the end of last year which has a JET septic tank system. I had a local vendor out today to do an inspection of the system and to explain the operation and required maintenance, as this is my first home on a septic.
As far as I understand I have two tanks with a concrete wall in between them, one collects the solids and the other allows the liquid to flow into the tank with the Jet Aerator Pump.
The vendor advised that the Jet Aerator Pump is no longer functioning in that while it is running and stirring, that no air is entering through the air inlet. He advised that my pump is the old style which does not allow for a rod to be put clear through to ensure there is no blockage. I was quoted approximately $695.00 for a new aerator pump.
My question is this:
It seemed to me that the pump literally just sits down inside the opening and plugs into the plug sitting under my cover. Is this something I can replace myself?
I found the Ultra-Air Model 375 online for only $395. It appears to be the exact same function as the 25+ year old one that I already have.
Is there any reason I couldn't purchase this pump for $395.00 and put in it in order to save myself the $300?
Thanks for any insight you all can provide!
slim05 is offline   Reply With Quote
Old 06-01-2016, 04:37 PM   #2
Rewards Points: 1,928
Re: Septic Tank Aerator - Need Some Advice
Contact your local heath department environmental division first.
Old 06-13-2017, 02:21 PM   #3
Rewards Points: 4
If the system was put in that soon then he is lying. No changes have been made to that pump in 10 years or more.
Wholesaleseptic is offline   Reply With Quote
Old 06-13-2017, 02:37 PM   #4
Lawrosa's Avatar
Rewards Points: 100
Why not get the updated 735 which is the same price..
Yes they just sit under the lid. Easy to replace..
Lawrosa is offline   Reply With Quote
Old 06-13-2017, 04:11 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 31,914
The post is over a year old. I think they found the answer by now.
Old 06-13-2017, 04:14 PM   #6
Lawrosa's Avatar
Rewards Points: 100
LOL.. Oh.. Im new here and dont check dates..
The mods should do a better job closing old threads IMO.
Or when someone adds to an old thread just close it with a note thread is old..
bob22 likes this.
Old 06-13-2017, 05:12 PM   #7
Super Moderator
joed's Avatar
The guy who brought it back to life looks like a septic seller possibly spamming the site.
Sealing septic tank lid...Issues? MANGINA Plumbing 11 01-16-2016 11:05 AM
Smell from septic tank gma2rjc Plumbing 46 05-20-2015 11:23 PM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 04:16 PM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
septic tank issue..options? jaycenter Plumbing 4 07-02-2010 08:05 PM
