On Septic System, Toilet Not Flushing But Gurgling - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2017, 01:36 PM   #1
Rewards Points: 8
On septic system, toilet not flushing but gurgling
We are on a septic system, house is 26 years old. Should we be able to see water at the top of the clean out pipe?
Sprymuse is offline   Reply With Quote
Old 04-27-2017, 01:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,298
Re: On septic system, toilet not flushing but gurgling
Should be empty. Is the tank full or blocked?
Old 04-27-2017, 01:55 PM   #3
Rewards Points: 8
Not sure. I'm thinking blocked...We are on a septic system, house is 26 years old. MB toilet stopped up, plunging can drain it but when flushed again, bowl fills up and doesn't drain. Last night, bathtub in MB drained but water came up through the shower! Now another toilet won't drain when flushed. We hear gurgling sounds from the toilets. Dishwasher ran but backed up in kitchen sink about an inch of soapy water, then drained. No water remained in dishwasher, it completed cycle. Snaked MB toilet and clean out pipe, no obstructions found. Water is visible in clean out pipe, but level varies when we do flush water from a 3rd toilet. Any ideas and feedback greatly appreciated. So who do we call?
Thanks!
Old 04-27-2017, 02:31 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
When was the tank last pumped?
rjniles is offline   Reply With Quote
Old 04-27-2017, 02:47 PM   #5
Rewards Points: 8
2012 when my stepdaughter was living here with her 2 kids. I use ridX most every month...
Old 04-27-2017, 05:30 PM   #6
RidX doesn't work.
Pull the lid and check the tank. Kids are notorious for flushing stuff that doesn't belong in a septic system.
Old 04-27-2017, 05:53 PM   #7
Rewards Points: 8
Smile
Thanks for your help! Hubby talked with a plumber who told him the clog probably was between the house and tank. Told him to use a special nozzle on the hose to dislodge it, and it worked! Back to normal functioning 😅
Tags
septic tank
Septic system overrun LadybugGA Plumbing 6 01-24-2016 04:56 PM
Gurgling sounds after flushing toilet Forestland Plumbing 3 10-10-2012 02:42 PM
Slow flushing toilet Kory Plumbing 1 11-26-2011 11:33 AM
Septic System Trouble vivaciousbee Plumbing 3 08-25-2011 02:33 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
