Septic System Overrun - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2015, 03:01 AM   #1
Septic system overrun
I am new to septic systems. Christmas eve i.had a problem with flushing not happening. We've had extremely heavy rains...6 inches in a day and many days. I called a septic company. They came out dug up my yard and took off the top of my tank. The water was to the top. They left it open and came back on the 26th and pumped it out. They put the top on and left.
Isn't there some way to relieve pressure on a septic system that doesn't require digging?
I paid a premium for an emergency dig and pump out. I've found information about clean out pipes. Why doesn't my system have it....and how much can I expect to pay to install one
The next issue is how can I keep this from reoccurring. Even with the pump out, my toilet is sluggish in the flush
LadybugGA is offline   Reply With Quote
Old 12-27-2015, 05:56 AM   #2
Rewards Points: 6,652
You are basically dealing with a system that has most likely never properly maintained.
If the tank was never drained and the leach field never inspected, you need to get it done.
If you have had alot of rain in a short period, yes the ground could be so saturated, that it will not take anymore.
Since the tank was just emptied. It is going to take a while to find out if the full tank was really the problem. You need to get the tank emptied per the schedule that the company that emptied it, gave you. Should be on the bill, along with aprox. gallons pumped out.
How long ago did you buy the place? Eas an inspection ever done on the tank and leach field? Also you should have been given record of when it was originally installed. If not. Your county should have it on file.
Old 12-27-2015, 06:41 AM   #3
Rewards Points: 18,762
https://www.google.com/search?q=sept...-qmQVV-NDoM%3A
Here's a drawing showing a basic septic tank layout showing a riser (clean out) that can be added to most septic tanks.
If the soil is saturated with water the effluent had no place to go.
That backup may well have caused solids to back up into the main drain line.
gregzoll (12-27-2015)
Old 12-27-2015, 08:23 AM   #4
Rewards Points: 3,262
It is likely that there was nothing wrong with the septic system, other than saturation of the leach field with rain.
An overfull septic tank usually means that there is nothing wrong with the tank and upstream and a simple inability of the downstream (the leach field) to absorb the water.
Normally the septic tank stays about 85% full and operates pay-as-you-go. As each gallon of new waste water comes in, a gallon of effluent should exit for the leach field.
Pumping the septic tank alleviates the overrun problem for a short period of time to get you past a rainy period, provided that rain water is not backing out of the leach field into the septic tank. What this task does is change the role of the septic tank into a holding tank until the rain subsides and the leach field naturally drains itself. After that you can test the leach field for normal versus substandard performance.
After a septic tank is pumped, nothing will exit for the leach field until the incoming waste water accumulates to the 85% full level.
Try some "jumbo toilet flushes" i.e. emptying large buckets of water into the toilet just fast enough to avoid overflowing onto the floor, to see if solids settling in the drain lines just prior to the pumping will continue on their own to the septic tank. You will need another person monitoring drains on lower floors so you stop pouring water in before any overflowing can happen down there if the solid material does not move as fast as you would expect.
A caution about having the drain snaked; it is possible to break the septic tank inlet baffle which will lead to long term leach field problems since fine solid matter won't settle to the bottom of the septic tank as fast as it should.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 01-24-2016, 01:53 PM   #5
If you are going to install a clean out pipe I would also install a back flow preventer in the pipe between the house and the septic tank. This will allow the effluent to flow into the tank & prevent it from flowing back into the house. To minimize the surface and ground water getting into the leach field a french drain can be installed uphill of the leach field. The french drain trench must be deeper than the leach field trenches to be effective.
Sent from my iPad using Tapatalk
John1961 is offline   Reply With Quote
Old 01-24-2016, 01:59 PM   #6
WhatRnsdownhill's Avatar
Rewards Points: 2,220
there is another thread on the same problem, your leach field is filling up with rain water, and causing a so called main line stoppage to the house, just like if you were hooked into a public sewer and had roots or some other obstruction...you need to figure out if the rain water is coming down hill into the leach field and redirect the water, or do you have any pitch away from the leach field, you can dig a trench before the leach field to the depth of the gravel base and fill the new trench with drain pipe in a gravel bed and run this down hill somewhere to drain the rain water before it soaks into the leach field, I had the same problem upstate at a mobile home I rent out, over the years the swell of dirt that kept the rain out of the leach field flattened out, so I dug with a backhoe a trench that I put in drain pipe in a gravel bed up to grade level before the leach field and ran it downhill away from the leach field..problem solved..
WhatRnsdownhill is offline   Reply With Quote
Old 01-24-2016, 04:56 PM   #7
Thanks everyone for your updates. It was several things. One was a poorly installed septic system that used a rubber boot to narrow a four inch pipe to a three inch pipe at the house. The rain did fill up the system from the leach field. And there three inch pipe was plugged.
Drip Emitter Septic System Aarone1972 Plumbing 4 04-09-2014 11:50 PM
Septic System, Failure and Replacement, Indiana imautoparts Plumbing 16 01-14-2014 07:45 PM
cost of septic lagoon system chulett Plumbing 0 05-09-2011 09:51 PM
Aerator fuse for septic system. waynealan Electrical 2 04-16-2011 11:00 PM
Septic System W/Water Softner wibass Plumbing 14 10-07-2008 09:42 AM
