Septic Leach Clean-out Pipe Hit When Landscaping - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2015, 07:15 PM   #1
Rewards Points: 14
Septic leach clean-out pipe hit when landscaping
I was having an area dug out and leveled for my son's new swing set. When digging the landscaper hit a leach bed clean out pipe. He finished the landscaping and put in the mulch. He dug down about 1 to 1.5 feet. I thought the area he was digging was far enough away from the field, but apparently not. What steps should I take?
rchewitt is offline   Reply With Quote
Old 06-10-2015, 08:31 PM   #2
Rewards Points: 18,972
Not sure how anyone would know without at least a picture and knowing what was damaged.
Why is he not fixing this?
Old 06-10-2015, 08:36 PM   #3
Rewards Points: 14
Sorry, it got dark before I could take pictures. For more detail, it's a 4 inch vertical pipe a 150 feet or more away from the tank itself. He said he didn't have a saw to cut the pipe. I can take pictures in the morning and post.
Old 06-11-2015, 04:04 PM   #4
Rewards Points: 1,910
Repair the damaged pipe and you probably need to pay him to put that 1 to 1.5 ft of soil back. Leach fields need a minimum amount of soil coverage.
Old 06-11-2015, 04:07 PM   #5
Because owner gave him the clearance to dig freely there. Sure he should have called the hotline first but it probably wouldn't have marked a septic field.
Old 06-11-2015, 05:22 PM   #6
Civil Engineer
Rewards Points: 5,246
Leach fields do not have a cleanout, they have a vent. You cannot clean the field through the vent, it is there to release gases and allow oxygen to get into the field. The vent is typically a four inch diameter vertical pipe, either ABS or PVC in my area. I assume the landscaper hit the vertical piece of pipe, if he dug deep enough to hit a buried horizontal leach field pipe you have a totally different problem.
If all he did was damage the vertical piece of pipe, just cut off the damaged section and glue on a new piece.
Old 06-11-2015, 06:30 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,246
Ayuh,.... I hate it when the owner don't really know where what is,.....
Old 06-12-2015, 08:24 AM   #8
Rewards Points: 3,130
Really?? My system, installed just 6 years ago, has no vent. Nor, apparently, do any of my neighbors' systems. Is this something new? Around here, the Health Department dictates system design and installation, so it's not as if the department-approved installer just forgot to do a vent.
Old 06-14-2015, 02:00 PM   #9
The pratice seems to vary by area. Some places they're vented other places not.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
Septic Tank pipe question Grady1 Plumbing 8 03-21-2012 10:23 AM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 06:05 PM
Septic tank outlet pipe broke in tank ClydeOspark Plumbing 2 04-04-2009 07:51 AM
