Selecting Pex Line Size? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2015, 11:08 AM   #1
Rewards Points: 290
Selecting Pex Line size?
I'm finishing up my man-cave, complete with a bathroom and wet bar. My house is primarily Copper pipe throughout, but for ease and cost reasons, I'm likely going with PEX to plumb the fixtures.
My problem is this: I don't know what size Pex to use (I know the inside diameter of Pex is less than that of copper)!
Coming off of the meter, the main water line is 1" copper. My bathroom is about 20' away from the line where I'd tee into.
My real problem is in the bathroom, I'll also be installing a urinal with a 3/4" flushometer.
Knowing this: Should I Tee off the main water line, then run 1" Pex all the way to the bathroom, and then Tee off again for the bar sink/dishwasher, bathroom sink, toilet and then reduce down to 3/4" for the urinal?
Or should I be okay Teeing off of the copper main, and running 3/4 PEX and Teeing off of that for the other fixtures?
Thanks for any help!
gizzygone is offline   Reply With Quote
Old 09-19-2015, 04:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 170
Run 1" to the bathroom. Also put an water hammer arrestor at the urinal
Old 09-19-2015, 05:31 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I would run 1" for the cold. Hot depends on what fixtures you will have.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 09-21-2015, 07:24 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,... Agreed,... 1 inch to the urinal, the biggest water user, then else where,...
probably 1/2" will easily feed the other uses,....
"T" off the 1" goin' by it, if necessary,....
Old 09-21-2015, 07:32 PM   #5
Rewards Points: 290
So bring a 1" main all the way to the urinal, before reducing to a 3/4" copper line to the flushometer?
Are we saying I shouldn't be putting a T on the 1", and that I should be using a separate 1/2" pex to the toilet and two sinks for the cold?
I thought the standard for sinks were 3/8" lines?
Old 09-21-2015, 08:00 PM   #6
Plumber
Rewards Points: 170
1" to the urinal. Reduce to 3/4" to supply one of the 3 remaining fixtures. Then 1/2" to the last 2 fixtures.
Also include a water hammer arrestor for the quick closing urinal flush valve.
Sinks and toilets are 3/8" but that is only the exposed supply lines. Inside the wall is typically done with 1/2"
Old 09-21-2015, 08:54 PM   #7
Rewards Points: 290
Sounds good. 1" all the way to the urinal before I "t" off.
Is there any reason to put a manifold in? Or is a couple of T's okay?
If I decided to go with copper instead of PEX, could I tee off before the urinal?
Old 09-21-2015, 09:29 PM   #8
Plumber
Rewards Points: 170
No need for a manifold.
Yes, you can tee off before the urinal, but the pipe size continuing to the urinal will depend on the tee or tees you install before it.
Example: 1x1x1/2 at 2 lavs, then 1x3/4x1/2 to toilet then 3/4" to urinal
The Following User Says Thank You to TheEplumber For This Useful Post:
gizzygone (11-21-2015)
Old 09-22-2015, 06:25 PM   #9
Rewards Points: 1,852
Urinal water line size is 3/4 always.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 11-18-2015, 09:29 PM   #10
Rewards Points: 290
Digging this back up again: 3/4" is typically the copper size, but if I go PEX, wouldn't I want 1" due to the smaller ID of PEX?
Old 11-18-2015, 09:31 PM   #11
Rewards Points: 2
I would also run 1"
carlpainter is offline   Reply With Quote
Old 11-19-2015, 12:37 PM   #12
Plumber
Rewards Points: 170
1" to the urinal branch. Then 3/4" copper stub out at the urinal
Old 11-19-2015, 02:47 PM   #13
Rewards Points: 290
Originally Posted by carlpainter View Post
I would also run 1"
Sounds like a direct 1" to the urinal is the way to go: do you think if I put the urinal as the first tee, and then continue the line to the toilet and sink I'd be okay? Or should I run 1" direct to the urinal and a separate line for the sink and toilet from the copper main?
Old 11-19-2015, 09:16 PM   #14
Plumber
Rewards Points: 170
You don't need a separate line.
1" will serve the group. You want 1" until the urinal- serve it with 3/4"
Old 11-21-2015, 09:29 AM   #15
Rewards Points: 290
Let's see if this works: Here's a crude schematic if what I'm hearing: is this correct?
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Suction line size kogashuko HVAC 5 07-07-2011 10:27 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Wire Size Help-400ft line to pond for fountain brownie47854 Electrical 14 04-22-2007 12:50 PM
