Securing Sharkbite Angle Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2015, 06:19 PM   #1
Rewards Points: 127
I have a couple of Sharkbite angle shut-off valves I plan to install to supply water to a new utility sink in the basement. I am tapping in to the washer water lines and I plan to run pex to the shuf-off valves. I attached a pic. What would be the best way to secure these valves to the wall? As you can see there are no mounting brackets to secure them. I looked all over the hardware store and on Sharkbite's website for a mounting bracket but no luck. Should I just get a bracket large enough to go around the valve and secure it that way? Thanks for the help.
wkumtrider is offline   Reply With Quote
Old 10-25-2015, 07:40 PM   #2
Rewards Points: 18,962
Back up and show us what it is your trying to tie into.
Are these lines inside a finished wall?
http://www.supplyhouse.com/Sioux-Chi...-Ear-6-x-3-1-2
Old 10-25-2015, 07:45 PM   #3
Rewards Points: 6,322
Research conduit strap clamp, or tubing clamp.
Old 10-25-2015, 08:07 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 248
A simple way is to put 2x? bock in the wall and drill it where you want the stub outs. Then use these pound in anchors to hold the pipe in place- drill 13/8" holes for these anchors. You should find them at the box store of your choice
http://www.ipscorp.com/plumbing/wate...pipeinsulators
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
wkumtrider (10-26-2015), Yodaman (10-26-2015)
Old 10-25-2015, 09:12 PM   #5
Rewards Points: 750
Why do you need it secure? Sharkbites are made to turn by design. If the turning does not cause any sort of malfunction, dont bother with it. That aside, if you need to secure it, you can try plumbing strap, or hose clamps, or zip ties or baling wire if you need something more heavy duty.
Or 2 shim 2X4 blocks, one on top & bottom screwed into the wall.
I mean, what you have to secure it to & how "pretty" you want it will kinda determine what you can use to secure it but there is many ways.
Hick is offline   Reply With Quote
Old 10-26-2015, 05:32 AM   #6
Rewards Points: 127
Thanks everyone. Hick, I thought about just leaving the valves hanging by the pex line, but didn't think this would be a good idea. These will be on the outside of a concrete basement wall. Thanks for all the replies. I'll look at the conduit straps mentioned.
Old 10-26-2015, 06:00 AM   #7
Rewards Points: 582
we use these....
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
Hick (10-27-2015), wkumtrider (10-26-2015), Yodaman (10-26-2015)
Old 10-26-2015, 06:08 AM   #8
Property Mgt/Maint
Rewards Points: 8,202
Pex to NPT drop ear (for next time). Use a valve that threads directly on or use a chrome nipple and chrome valve for interior finish plumbing.
On concrete walls I would mount these drop ears on a treated board that was fastened to the wall.
Upstairs under the sinks, mount just behind the drywall and use a chrome nipple and valve
http://www.supplyhouse.com/Rifeng-H1...FUOQHwod0vwA3w
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 10-26-2015, 11:01 AM   #9
Property Mgt/Maint
Originally Posted by ben's plumbing View Post
we use these....
Are the valves replacablre?
not sure why the pic didn't copy down
Old 10-26-2015, 04:53 PM   #10
Rewards Points: 582
yes they are 5/8 compression
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 10-27-2015, 01:31 PM   #11
Rewards Points: 750
Concrete wall. Well, a concrete drill bit, concrete screws & a treated board (probably a 2X4 or 2X6) & plumbing strap would be the easiest/cheapest option. You could skip the treated board but I wouldn't suggest it.
Old 10-27-2015, 04:07 PM   #12
Rewards Points: 582
on concrete we also use these van hangers..
wkumtrider (10-28-2015)
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
angle valve soldered on gal. steel pipe? flitz Plumbing 9 03-02-2010 07:31 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
