Secondary Water Source - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2017, 01:29 PM   #1
Rewards Points: 4
I live in the area that there is no public water utilities. So I have my own well. I just got a 400 gallons stainless steel water tank. I can set it up to fill it with rain water. I can also can pump water from the well to it. However, I want to use rain water as the primary source of water and the water from well as the secondary. How can I do that?
I know that I can automatically pump water from the well to the tank if the water level lower that a certain level. But if and only if the well water is the primary source.
I also have a entire house water filtration system.
Greatly appreciate any ideas / suggestions.
zogzag is offline   Reply With Quote
Old 09-15-2017, 02:29 PM   #2
retired framer
Rewards Points: 15,048
Re: Secondary Water Source
Could you not use floats in the tank like you would with a sump pump.
Hot water cross over mystery maroonw Plumbing 4 04-29-2016 05:14 AM
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
