Second Check Valve Here? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2016, 09:57 PM   #1
Rewards Points: 14
System is as follows: Well pump, holding tank, pressure pump, house.
At the pressure pump, I have it set up where the feed is coming from a lower bulkhead on the tank instead of an upper, so water flows down into the pump instead of the pump lifting the water (what these shallow well pumps are designed to do).
Normally you'd use a foot valve, but that wouldn't work with this setup.
So do I just stick a standard half pound spring check valve between the tank and the pressure pump? Right now the pressure pump won't maintain pressure, because it back feeds into the tank every time it clicks off.
Awek99 is offline   Reply With Quote
Old 05-14-2016, 10:31 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,586
Re: Second Check Valve Here?
An inline check valve between the tank and pump is what you need. The type you use is your choice. I like this type with the flapper.
The Following User Says Thank You to joed For This Useful Post:
Awek99 (05-15-2016)
Old 05-15-2016, 12:02 AM   #3
Rewards Points: 14
That's what I've got on the top of the pump, but I thought they worked better sitting upright, whereas the plastic spring loaded would be able to sit upside down/sideways or whatever direction it pleased. Will the brass flapper style work in any direction?
Old 05-15-2016, 06:28 AM   #4
Super Moderator
joed's Avatar
It will not work in any direction. Just my preference. I like the cap for priming if needed.
The inline spring loaded ones are fine as well.
Awek99 (05-15-2016)
Old 05-15-2016, 11:15 AM   #5
Rewards Points: 14
That's what I thought. Yeah, I like them better as well. That's what I put on the top of the pump.
This one will be sitting sideways, so I need the spring.
Old 05-15-2016, 11:30 AM   #6
Rewards Points: 14
Here's the pump.
Old 05-15-2016, 12:25 PM   #7
Super Moderator
joed's Avatar
While your at it I think I would put a shut off at the bottom of the tank. Then you can work on the pump without draining the tank. That check valve can sit sideways. It does not need to be vertical. The flapper does not sit vertical. There is a bit of an angle so that is seals when sitting flat.
I think what I would do is an elbow, a shutoff and then the check valve. Keeps the connection from sticking out too far from the tank and being susceptible to being knocked off. The elbow can point sideways or straight up.
Old 05-15-2016, 01:23 PM   #8
Rewards Points: 14
Ok, a 90 similar to the top bulkhead. I've got another brass check sitting around here somewhere, I'll stick it on today. Tomorrow I'll go grab a shut off valve, because you make a good point there.
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
condensate pump needs check valve replacement too often needsleep HVAC 13 01-15-2016 06:42 AM
Quiet Check Valve Installation shane1234 Plumbing 3 08-04-2015 05:02 PM
Best 2 inch pvc check valve? bassadict69 Landscaping & Lawn Care 1 08-02-2015 07:02 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
