Sealing Off Shower Drain??? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By DR P
Old 01-19-2018, 09:23 AM   #1
Rewards Points: 26
Sealing off shower drain???
I would like to remove a stand up shower in my full bathroom and make it a half bathroom. What can I use to seal off the shower drain so I can tile over it? Thanks
Questnyc is offline   Reply With Quote
Old 01-19-2018, 09:45 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,896
Re: Sealing off shower drain???
We don't know what you have for a shower drain...... probably 2" ABS..???
But your local big Box store will have multiple type plugs/caps that will glue on or presure fit on.........
MTN REMODEL LLC is offline   Reply With Quote
Old 01-19-2018, 09:55 AM   #3
Rewards Points: 26
Thanks for the reply. I havenít got to that part yet to know what type of pipe it is. Just was trying to gather as much knowledge as I can before I started the project. Is there a specific name for the plug for the shower drain?
Old 01-19-2018, 10:36 AM   #4
Depends on exactly what you have..... sometimes called test caps/plugs
Old 01-19-2018, 10:39 AM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
this type should work well:
https://www.ebarnett.com/Sku/301159/...All%20Products
Peace
MTN REMODEL LLC likes this.
DR P is offline   Reply With Quote
Old 01-20-2018, 12:18 PM   #6
Rewards Points: 26
Thanks a lot fellas
Old 01-20-2018, 08:51 PM   #7
Guapo
Rewards Points: 11,950
Are you sure that you want to remove that shower? It certainly lowers resale value?
Guap0_ is offline   Reply With Quote
Old 01-20-2018, 10:23 PM   #8
Rewards Points: 26
Iím not worried about resale value. Iím already up by about 100k. I have 2 full bathrooms upstairs. The downstairs bathroom is a full bathroom which is kind of weird because no one uses it to shower and Iíd rather make it into an elegant half bathroom for my guest.
Old 01-21-2018, 05:54 AM   #9
Guapo
Ok, I just thought that I would mention it.
Adding new shower drain to toilet drain? w layout pics BNR34RB26DETT Plumbing 25 02-11-2015 09:55 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 12:49 AM
