Sealing Exhaust Penetration In Block Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2018, 08:08 PM   #1
Rewards Points: 254
Sealing exhaust penetration in block wall
I recently replaced my water heater and had to remove the exhaust in the process (gas water heater) It vents into the chimney along with my boiler. The previous owners used some material that flaked off and now I have this:
I have used the quickrete patch before in the past with good results, but given there will be heat involved here I am not sure if that will work. Can I use great stuff? Something else?
JSDNJ is offline   Reply With Quote
Old 02-27-2018, 06:23 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,250
Re: Sealing exhaust penetration in block wall
Ayuh,.... I'd use no-shrink grout to patch that up,...... But,....
I don't think it's legal to vent 2 appliances into a single flue,....
Old 02-27-2018, 06:46 AM   #3
Property Mgt/Maint
Rewards Points: 8,202
NS grout, reg. mortar, or refractory mortar will work. No great stuff.
It's ok to vent the furnace and HW tank into the same chimney. Where you have a problem is when you upgrade the furnace to HE, and strand the HW by itself into the chimney. Alone, the HW will not generate enough heat to keep the clay liner dry.
You can not combine any gas appliance vent with a fire burning exhaust, like coal, wood, pellets, etc.
Yodaman is offline   Reply With Quote
Old 02-27-2018, 02:03 PM   #4
Rewards Points: 254
Got any specific recommendations?
I just have to be careful when applying because I donít want any material to fall into the boiler exhaust.
This is in a chimney shared with my wood burning fireplace but in a separate flu.
Old 02-27-2018, 03:33 PM   #5
Rewards Points: 254
Anyone have experience with this stuff?
https://www.homedepot.com/p/Hercules...5515/202078154
Old 02-27-2018, 05:26 PM   #6
Property Mgt/Maint
I have not used this specific product, but it should work perfectly.
Retaining wall against brick+cement block foundation. Waterproofing options? homeimproverjoe Landscaping & Lawn Care 3 03-20-2017 02:47 PM
Retaining Wall - Native Soil Behind Buried Block Branden Concrete, Stone & Masonry 3 08-26-2016 01:25 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
