Sealant Question For 10-15 PSI - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2018, 01:51 PM   #1
Rewards Points: 2,246
Sealant question for 10-15 PSI
Hello to all,
The pool has a 4-cartridge filtering system. The cartridges are about 32" inches tall and 6-7" diameter w 2-3" holes in centers . The [soft] plastic ends have a few 1/2" to 3/4" splits in them. The pleats are in great shape, but I was trying to determine if any of you guys know of a sealant/filler that I could use to plug/seal the splits? JB weld for water applications???
The water chemistry is about a 3-5ppm Chlorine and a pH of 7.4 - 7.8, and the cartridges are enclosed/submerged in a fiberglass housing. The max PSI would be 15 maybe at start-up as pump primes, but operating is anywhere from 2-8 psi.
thank you very much, tstex
tstex is offline   Reply With Quote
Old 03-17-2018, 08:12 PM   #2
Rewards Points: 126
Re: Sealant question for 10-15 PSI
Originally Posted by tstex View Post
Hello to all,
Unsure what exactly you are looking at, haven't worked much with pool filtration/pump systems. Perhaps a few pictures so we can see what you're working with
akuhn235 is offline   Reply With Quote
Old 03-18-2018, 08:59 AM   #3
akuhn,
Here's a stock pic of the cartridge that is like mine...it's actually 32" long and 6-7" diameter. The next pic is of my pool equipment pad...the pool housing is the larger light brown canister...thanks
Sealant question for 10-15 PSI-pool-cartridge.jpg   Sealant question for 10-15 PSI-pool-skimmer3.jpg
Old 03-18-2018, 10:34 AM   #4
hkstroud's Avatar
Rewards Points: 6,694
Now I know absolutely nothing about this but;
I wonder if the ends could be PVC.
If so you could try PVC primer and glue.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 03-18-2018, 10:54 AM   #5
Thanks Harold...I did not know anything about these matters until I owned one [sigh].
The ends are not like PVC, but more like the bottom of some sports shoes, where the plastic is clear and not 100% hard, but has movement to it...I hope this helps...I am thinking it's more like hardened silicone...thanks again
sealant question - in the long 1 and 1/2 ft thin aluminum "sausage " type container hidden1 General DIY Discussions 11 10-24-2012 06:43 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
Grill Sealant Question hugg0029 General DIY Discussions 4 05-26-2009 12:02 PM
Question about pipe sealant and simply derp Appliances 2 05-04-2009 10:25 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
