Screw On My Bath Faucet Is No Longer Usable :( - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By hkstroud
Old 08-24-2016, 02:16 PM   #1
Rewards Points: 26
Question
Screw on my bath faucet is no longer usable :(
The groove on my screw is no longer good, so I can't continue using the screwdriver to remove it.
This faucet had become too tight. It's pretty old.
What should I do?
Thanks guys
DPC
drpeppercan is offline   Reply With Quote
Old 08-24-2016, 02:46 PM   #2
Rewards Points: 2,648
Re: Screw on my bath faucet is no longer usable :(
Can usually buy a new screw.
How about describing what screw into what part of your faucet.
bob22 is online now   Reply With Quote
Old 08-24-2016, 03:14 PM   #3
Rewards Points: 3,476
Are we talking about a bathroom sink, shower, etc. Please post a couple pics. Thanks.
Sometimes an ez out works. Then replace with a new screw.
Another option, If its that old, you might want to consider replacing the faucet.
jmon is online now   Reply With Quote
Old 08-24-2016, 04:17 PM   #4
Rewards Points: 18
Drill it and then use a screw extractor.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 08-24-2016, 05:45 PM   #5
Rewards Points: 26
Thumbs up
I knew I had forgotten something! (the photo)
I would put the photo now, but I'm still not allowed
Yeah, sounds like I'd have to go with jeffmattero76īs advice.
I couldn't find a used screw extractor, so a new set would cost me about $70 CAN at Canadian Tire a local hardware store. I would have put a link to that extractor, except I'm not allowed to put links either yet
Just in case paying a plumber were more affordable I requested quotes from some local plumbers already.
DPC
Old 08-24-2016, 06:10 PM   #6
Rewards Points: 6,516
Drill the head off. Remove the knob. Run a nut down on the screw below the screw end surface. For small screws, cut a new screw slot centered and deep in the screw end with a hack saw blade that has the tooth set ground off. Back the nut up to at least flush or just above. Back the screw out.
If the screw is stuck tight do not screw around with a pair of vise grips. They will only tend to screw themselves off because of the threads and screw things up worse.
Old 08-24-2016, 07:21 PM   #7
hkstroud's Avatar
Rewards Points: 6,694
Pick up the kit shown below from Sears. Item number 52154. About $12
Chuck small bit in drill, follow instructions and go slow. Run drill in reverse.
It will either remove screw or it will cut away the head of the screw.
If it cuts away the head of the screw you can then remove handle and use pliers to remove remainder of screw.
de-nagorg and jeffmattero76 like this.
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Chris130 (08-24-2016)
Old 08-24-2016, 10:36 PM   #8
JUSTA MEMBER
Rewards Points: 3,924
Once you get the knob off and can't get the screw out, just replace the entire stem assembly.
They sell new stems at most BOX stores.
ED
de-nagorg is offline   Reply With Quote
Old 08-27-2016, 07:54 AM   #9
Rewards Points: 1,528
I think new budget faucet would be better than sinking money on tools and replacement parts. Plumbing fixture screws, usually brass, may be too soft for extractors. Problem is rust or mineral and extractors don't work. If you end up breaking the handle, again, new fixture is better deal.
carpdad is offline   Reply With Quote
Old 08-27-2016, 08:46 AM   #10
I agree with Carpdad. Likely time for a new fixture.
Old 08-30-2016, 10:13 AM   #11
Rewards Points: 26
Thank you so much to everyone for chipping in
It was so helpful.
Now I can move on!
Btw, do I need to remove that screw to replace the fixture? I hope not
That's true! Now I can, here...
Old 08-30-2016, 10:24 AM   #12
JUSTA MEMBER
Picture please, now that you are a multi-poster, you are allowed.
We do not know what fixture you have.
ED
Old 08-30-2016, 11:27 AM   #13
Look under the counter and you will see what you'll need to loosen to remove the faucet handles and spout etc...
Old 08-30-2016, 12:19 PM   #14
JUSTA MEMBER
Now ZOOM OUT some, so we can see the entire fixture.
That screw is still removable with the right experience and tools.
ED
Bath Tube Faucet Leaking jswolfe Plumbing 4 12-07-2015 10:09 PM
Bath tub faucet - older home mulvihwm Plumbing 4 09-14-2014 12:15 PM
wall mount bath faucet rough in DIYMario Plumbing 4 05-28-2013 08:50 PM
Is there a longer bath tub drain flange? Lined cast iron tub. kokobeans Plumbing 0 11-18-2012 09:56 AM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 06:38 PM
