Sch 80 Male Adaptor In Sump Pump Discharge, When Rest Of System Is Sch 40 - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2015, 11:53 AM   #1
Rewards Points: 392
Question
Sch 80 male adaptor in sump pump discharge, when rest of system is Sch 40
Is this valid?
enochian is offline   Reply With Quote
Old 07-12-2015, 01:50 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 16
Originally Posted by enochian View Post
Is this valid?
Sure, its stronger than sch 40
The Following User Says Thank You to TheEplumber For This Useful Post:
SHR Plumber (07-13-2015)
Old 07-12-2015, 03:37 PM   #3
Rewards Points: 392
What is that sleeve-like adapter I've seen people use in their sump pump discharge?
Old 07-13-2015, 03:16 AM   #4
Rewards Points: 38
Probably a check valve. A must have, never install a sump pump discharge without an in-line check valve.
SHR Plumber is offline   Reply With Quote
Old 07-13-2015, 08:37 AM   #5
Rewards Points: 456
Not to change the topic, but never seems like a long time. If you've a short upwards length on the discharge (say 12'') and then a downwards slope, why install a check valve?
bob22 is offline   Reply With Quote
Old 07-13-2015, 11:04 AM   #6
Rewards Points: 392
No its not the check valve.
Old 07-13-2015, 11:33 AM   #7
Plumber
Rewards Points: 16
Are you referring to a Fernco coupling?
Sent from my HTC6525LVW using Tapatalk
Old 07-13-2015, 12:24 PM   #8
Rewards Points: 392
Its like a copper-colored male adapter.
Old 07-13-2015, 01:44 PM   #9
Rewards Points: 92
Please post a picture of it. Thanks.
jmon is offline   Reply With Quote
Old 07-15-2015, 02:06 PM   #10
Rewards Points: 38
Always install a check valve on the discharge. Even with a short rise it will reduce wear on the pump. It also creates a barrier to critters trying to move through the line in to your house.
But as I often point out, when your pump wears out and you need someone to change it out feel free to call one of us plumbers. We like the money.
Old 07-15-2015, 07:20 PM   #11
Rewards Points: 392
Thats why I asked.
Old 07-15-2015, 08:52 PM   #12
Rewards Points: 286
May well be a sump pump silencer or "soft close" check valve-prevents loud thud with valve closure.
Sch 80 male adaptor in sump pump discharge,  when rest of system is Sch 40-fh08sep_cheval_02.jpg
ProGreen is offline   Reply With Quote
Sump Pump Discharge - Below grade good or bad? ricksample12 Painting 1 06-24-2015 11:51 AM
Sump Pump/ French Drain Advice jackislost Landscaping & Lawn Care 7 06-21-2015 09:23 PM
Sump Pump discharge question hubaseball02 Plumbing 11 03-30-2012 05:56 PM
I need triple sump pump setup system jazzyj Plumbing 12 01-26-2012 11:06 AM
how/where to discharge sump pump downers Plumbing 8 06-18-2008 06:18 PM
