S-trap Leak - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By rjniles
Old 10-31-2016, 07:44 AM   #1
S-trap leak
I hooked up a new basement vanity sink install a simple S-trap. I am having water come out of the top of down tube. I am thinking maybe I just need to cut off the down tube shorter. Any thoughts.
Reynolds is offline   Reply With Quote
Old 10-31-2016, 08:15 AM   #2
Rewards Points: 18,768
Re: S-trap leak
Need a picture so we can see what your seeing.
Old 10-31-2016, 08:34 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: S-trap leak
S traps are not compliant, you should have installed a P trap. +1 on the picture.
SHR Plumber likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 11-02-2016, 08:45 AM   #4
Re: S-trap leak
I appreciate all the responses. Upon further inspection apparently the down tube from the vanity that had been out of the box had a loose nut, tighten that and tighten everything else. Again this is a basement bathroom that is being redone, I was not aware the S-trap was not compliant.
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 08:47 PM
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Leak every 5 months LValley Plumbing 4 11-05-2012 01:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Freon Leak captainron19 HVAC 3 04-16-2010 04:30 PM
