Ruud Water Heater Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2016, 10:04 AM   #1
raylo32's Avatar
Rewards Points: 1,526
Ruud water heater problem
Ruud model # PE52-1 C, 50 gallon electric
This morning my GF's water heater ran out of hot water during 2 showers. Never happened befor and should never happen with a 50 gallon unit. We checked the water later and it was not warming up. Flipped the breaker off and back on and now it seems like it is recovering (will check in about 30 minutes and report). I don't have my tools or meter to ohm out the element (yes, element singular, the label plate is blank for upper and the total wattage is the same as listed for the lower - 5500W).
If I need an element are these things universal... and hopefully available at Lowes?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 04-17-2016, 10:23 AM   #2
raylo32's Avatar
Re: Ruud water heater problem
Well, it seems to be recovering. I'll check it again this evening after hiking. Also, I pulled the top element well cover and see it is the screw-in type (upper well just had a blank cap) so I know what type to get if I need it.
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
water heater problem Jeremy Hillary Boob, PhD Electrical 7 01-06-2013 05:08 PM
**I just installed my RHEEM ECO-SENSE 180DVN3 tankless water heater 57_Hemi Plumbing 21 01-03-2013 11:32 AM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
