Ruptured Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By chandler48
  • 1 Post By tom_poconos
  • 1 Post By Gregsoldtruck79
Old 01-11-2018, 10:01 PM   #1
tom_poconos's Avatar
Rewards Points: 508
Question
Ruptured water heater?
Today I replaced our old leaking well pressure tank. The old tank was on a 30/50 cut-in/cut-out a the new one is on a 40/60 cut-in/cut-out. Everything went smoothly. I was about to go make myself a Pina Colada to celebrate then noticed the water heater was leaking from the bottom. Upon close inspection none of the fittings were leaking (hot, cold, drain), and the pressure relief was not venting at all. All I can think of is the new system pressure (10-15 PSI more than usual) ruptured the water heater. Could this be the case?
The water heater is 11 years old and has been subject to moderately hard well water. When I opened the drain valve there was some pretty thick orange water coming out for a while. Maybe the anode was gone and it just needed a little push to burst a leak?
tom_poconos is offline   Reply With Quote
Old 01-11-2018, 10:24 PM   #2
JUSTA MEMBER
Rewards Points: 3,790
Re: Ruptured water heater?
If you don't drain water heater tanks annually to get rid of the sediments that hard water makes, the anode will burn out, then the crud rusts out the bottom of the tank.
So probably you need a new tank, because the higher pressure finished the rust out.
Sorry for the bad news, but your pina colada will have to wait until you get a tank installed.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
tom_poconos (01-11-2018)
Old 01-12-2018, 05:23 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,508
On average EOL of a water heater is 12 years, and less with poor water quality, so you got all the goodies out of the tank. Actually 40/60 is a better setting, and should not cause any problems on a good system.
joecaption likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
tom_poconos (01-12-2018)
Old 01-12-2018, 09:41 AM   #4
Rewards Points: 508
Thanks - picking up a new water heater today.
de-nagorg likes this.
Old 01-12-2018, 09:49 AM   #5
Rewards Points: 88
And many will find out as I did after draining my WH twice a year, the factory plastic drain cock will probably start dripping. So I got rid of mine.
Gregsoldtruck79 is offline   Reply With Quote
The Following User Says Thank You to Gregsoldtruck79 For This Useful Post:
Old 01-12-2018, 10:59 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Two nits to pick, well maybe 3. Replace the plastic drain valve when you install a new WH. Use a brass nipple vs galvy. Use a full flow ball valve style sillcock.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
New-ish electric hot water heater blowing fuses. roasted Electrical 33 01-11-2017 01:24 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
