Running Supply Line For Icemaker - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By Ghostmaker
Old 03-17-2017, 10:33 AM   #1
Rewards Points: 30
Running supply line for icemaker
Dayton Ohio area. Our kitchen is on a slab and the original builder did not run a supply line for the fridge icemaker. My only choice is to go from the kitchen bar wall on the right overhead thru the attic and drop back down behind the refrigerator. These are both interior walls. Dishwasher is on the end next to the wall I want to go up so getting connected there isn't an issue. House is all copper. For this application should I use a Pex ? with a heavy foam pipe insulation and keep it along the ceiling under the insulation in the attic to prevent freezing?
Cattman is offline   Reply With Quote
Old 03-17-2017, 10:38 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,832
Re: Running supply line for icemaker
Oh boy..... Hate to run any plumbing on outside walls/attics and I bet IN/OH can get pretty cold.
Any chance you can snake any supply through (or on top of) your cabinetry.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-17-2017, 11:29 AM   #3
Rewards Points: 6,320
[QUOTE=Cattman; with a heavy foam pipe insulation and keep it along the ceiling under the insulation in the attic to prevent freezing?[/QUOTE]
That would be insulating the room heat, that will keep the pipe from freezing, away from the pipe. Do not insulate the pipe but as you mentioned keep the pipe on the living quarters side of the attic insulation.
Old 03-17-2017, 11:37 AM   #4
Rewards Points: 30
There is no way to run it on the inside without building a bulkhead from the island to the wall the fridge is on. Running supply line for icemaker-house-12.jpg
Old 03-17-2017, 02:28 PM   #5
Rewards Points: 1,928
I would get the ice maker on your next house. Or wait until you redo the floor to run it underground. Attic is not a good option. With no heat source it will freeze.
Do you have any water on the other side of the refrigerator or cabinet area?
Ghostmaker is online now   Reply With Quote
Old 03-18-2017, 08:37 AM   #6
Bob Sanders's Avatar
Rewards Points: 2,536
Run an insulated 6 inch air duct through the unheated space. Leave both ends of the air duct opened and exposed into the heated space. It can be open inside the interior walls just so long the ends are in heated space. Run your water line through that.
I have had two 1/2 inch copper lines running this way through an unheated crawl space for 20 years and never had a problem, and I'm in Manitoba where we go down to -40 in the Winter.
Bob Sanders is offline   Reply With Quote
Old 03-18-2017, 03:26 PM   #7
hkstroud's Avatar
Rewards Points: 6,694
I would run a 1/4" soft copper line up the end of the kitchen bar wall to the attic like you plan. Just keep it between the ceiling drywall and the insulation in the attic. If necessary bore through the bottom edge of any ceiling joist. It won't freeze there unless your kitchen ceiling is freezing.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 03-18-2017, 03:55 PM   #8
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,696
Ceiling joist could be part of a truss.
123pugsy is offline   Reply With Quote
Old 03-18-2017, 04:06 PM   #9
hkstroud's Avatar
So? Nothing says you can drill a truss joist. Only need a 1/2 to 5/8 hole.
They could also be running parallel to run of the copper .
Harold,
Old 03-18-2017, 04:26 PM   #10
123pugsy's Avatar
No truss drilling here.
Parallel would make it easy.
Old 03-18-2017, 04:30 PM   #11
hkstroud's Avatar
Run it across the top of joist. Lay a bat of insulation on top of the copper.
This is Ohio, not Polar Bear country
Harold,
Old 03-18-2017, 04:35 PM   #12
I would not run copper through drywall again without sleeving it. Plastic for me.
Old 03-18-2017, 06:12 PM   #13
If your going to run it run it in 1/4 inch pex so if it does freeze it will not burst open.
TheEplumber and SHR Plumber like this.
main supply line needs to be replaced - your thoughts NABRIL Plumbing 7 03-16-2014 07:42 PM
Main Toilet Supply Line Clogged? Redskins-21 Plumbing 10 01-27-2014 05:27 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 08:51 AM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 11:26 AM
