Running Propane Line - Looking For Input On Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2016, 05:46 PM   #1
Rewards Points: 58
Running Propane Line - looking for input on location
We are installing a gas range and I need to add a propane tank. For now I am using a 100lb tank outside. I need to run the black pipe out of the house. Looking a the pic of the crawlspace - I was going to shoot for the upper portion where the water line is to run the gas line.
1. Its less to go through - when compared to the masonry blocks.
2. Its higher so there will be less black pip used, can drop down 6 inches from stove and go horizontal.
Any reasons not to put a 1/2 hole here and go lower?
dman535 is offline   Reply With Quote
Old 09-22-2016, 07:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 180
Re: Running Propane Line - looking for input on location
That's a good plan gas/propane cannot enter the crawl space below grade- so the rim joist is your best option.
Also, regulators are restricted to certain exterior locations. Be sure to check with your local provider on their reg. requirements
Old 09-23-2016, 06:26 PM   #3
Rewards Points: 58
I figured I can start with a spade bit for the wood - any suggestions for going through the brick and not making a mess? I figured if I was going through the cement blocks I would need a hammer drill, but for just the brick can I get away without one ?
Old 09-23-2016, 06:39 PM   #4
Rewards Points: 18,796
If you have hours instead of min. to spare a regular drill will work.
Make sure to drill from the outside in to prevent a blow out.
location of condensate drain line nugentcn HVAC 7 06-28-2015 04:50 PM
Need help on running gas line to detached garage gjones Plumbing 2 05-22-2012 06:30 AM
Braided Flex Line for propane kphares Plumbing 2 01-01-2011 08:54 AM
Propane Gas Line Question - U-turn? DangerMouse Plumbing 6 06-03-2010 02:18 PM
Remove fitting from propane line btrevillyan Plumbing 2 06-02-2009 09:55 PM
